Main > Main Forum
Happs 3" Trakball, High or regular?
Frostillicus:
--- Quote from: Homebrew on April 29, 2003, 09:24:22 pm ---FYI, according to happ's schematics, the only difference between the regular and the highball is the top half of the casing. I'm sure if you called happ you could get just that piece, or at worst the whole plastic case. Either way i can' t imagine it would be that expensive. Then you could have both and decide what you liked best. I'm considering that myself as i have the regular now. Here's the links to the schematics for each. You can see what part# is different.
http://www.happcontrols.com/trackballs/560110e.htm
http://www.happcontrols.com/trackballs/560100e.htm
-Kevin
That top bracket costs:
Item # In Stock Qty Description Prices Order Options
95-1266-00 Yes 3" TRACKBALL SHORT TOP BRACKET HIGH-BALL VERSION 1+: $ 3.55
The price diff between the reg and highball is like 6 bucks, FWIW.
u_rebelscum:
--- Quote from: Frostillicus on April 29, 2003, 10:32:11 pm ---
--- Quote from: Homebrew on April 29, 2003, 09:24:22 pm ---FYI, according to happ's schematics, the only difference between the regular and the highball is the top half of the casing. I'm sure if you called happ you could get just that piece, or at worst the whole plastic case. ... You can see what part# is different.
-Kevin
Great info you guys!
The highlip is just the same as the normal except for the top half of the case.* It's also on sale until the 30th of april.
* I'm sort of guessing, because the links on the happ site show the normal exploded view for the highlip model.
Homebrew:
Actually its the golden tee trackball thats on sale. I'm not sure if its any different or not since happ just reused the schematic for the regular trackball on it. Hopefully theres no difference except the new redboard optics and the white trackball. Hey Frostillicus how did you find that on Happ's site? I did a search but came up with nothing.
-Kevin
Brax:
If I had the old optics board (green?) is it possible to "upgrade" to the red board somehow?
Frostillicus:
--- Quote from: Homebrew on April 30, 2003, 05:56:03 am ---Hey Frostillicus how did you find that on Happ's site? I did a search but came up with nothing.
-Kevin
I have mad happ skillz, that's how ;) Heh actually just manually enter the parts # into the little dialog boxes they have. You may have to actually add something to your cart to find the right dialog box (should say "Enter part number:"), but you can always just delete it later.
