Author Topic: Can't get trackball to work in Mame game launched from AtomicFE  (Read 3047 times)
nickbuol
  • Last login:July 20, 2023, 03:27:15 pm
  • 2nd Time Around
If I need to look somewhere else, please let me know.  I've tried searching too.
Anyway, I have a Happ USB trackball that works in Windows XP, works for selecting games in AtomicFE, but when I launch a game, such as one of the Golden Tee golf (trackball version) games, the trackball isn't recognized in the game.  What am I missing?  I am sure that it is something simply stupid on my part.  This is my 4th arcade build, but they are so few and far between that I end up reworking everything, including front ends, and so maybe a previous front end was doing something for me that I need to still set up in AtomicFE....
Any ideas?
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
Re: Can't get trackball to work in Mame game launched from AtomicFE
« Reply #1 on: August 30, 2007, 01:30:00 am »
It seems a problem of MAME configuration (assuming you are using mame). It could be good if you can tell us wich version are you using.
Anyway, firstly, in mame.ini, check this:
mouse  1
trackball mouse
multimouse 0
If you don't have one option, don't add it. Only verify the values (1,mouse,0)
Try it now.
« Last Edit: August 30, 2007, 01:31:47 am by Cananas »
nickbuol
  • 2nd Time Around
« Reply #2 on: August 30, 2007, 01:34:47 am »
Latest version of Mame.  I will check the .INI tomorrow (I really should have been in bed hours ago)...  Thanks...
Green Giant
« Reply #3 on: August 30, 2007, 01:40:50 am »
Doesn't atomic have options to enable mame features such as trackball where it modifies the .ini for you?
Also, did you go into the mame menu, press tab, and setup the controls for using a trackball?  Press input for the x direction and move your mouse to the left, same for y direction?
Toxic Arcade, my first build
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #4 on: August 30, 2007, 06:56:44 am »
No Atomic does not configure (not yet)  emulators  for you.   Trackball support options you see in Atomic are only for the Front End itself.
http://spaceinvaders.7.forumer.com/viewtopic.php?t=778
nickbuol
  • 2nd Time Around
« Reply #5 on: August 30, 2007, 08:34:46 am »
I knew that it would be something simple...  Mouse 1 is the setting that I needed to change in mame.ini....
Thanks everyone.
