Author Topic: mamewah + wingun + instant sheller problems  (Read 1504 times)
Pitou
  • Last login:May 28, 2020, 05:56:46 pm
« on: August 29, 2007, 09:54:46 am »
Hello,
Question #1
At the moment, I'm using "instant sheller" to start mamewah when powering up my PC (hiding windows XP).
Now I'm adding a LCD topgun using Wingun. I know I can use wingun -m to start it minimized.
Where should I put this command line?
Does "instant sheller" inhibits all windows startup procedure?
Question #2
When using Wingun, mame 0.118 doesn't detect any button when trying to map the trigger. Any idea?
Last thing. I really prefer Wingun over Guncon2 PC driver for it's calibration process. Wingun is dead on with only 1 calibration, although with Guncon2 PC drive, I never succeeded making it precise, I'm always offset in the bottom right corner.
Any hints?
Thanks.
Pitou!
morourke
  • Last login:January 19, 2008, 10:54:38 pm
Re: mamewah + wingun + instant sheller problems
« Reply #1 on: January 02, 2008, 12:04:17 pm »
I'm having the same problem. I can't get the trigger to work in Mame with WinGun but it does with GunCon2. However, the calibration is SO much better in WinGun. I've gone into the Mame config menu and tried to change the trigger but it doesn't even notice the pulled trigger.
Did you ever get a resolution to this?
Michael
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« Reply #2 on: March 06, 2008, 10:51:46 am »
Did either of you?
I am having the same problem.  Excellent calibration, no trigger.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #3 on: March 06, 2008, 01:25:00 pm »
Hi guys, do you have multimouse turned on?  I tried Wingun once and I didn't like it so I went back to Guncon2pc.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #4 on: March 07, 2008, 03:43:51 pm »
I've had two Topguns now for ages, but I've had so many problems trying to get it to work in different situations, I've left them alone for a while. I wish there were a definitive start-to-finish guide, with sources, pictures and downloads.
« Reply #5 on: March 08, 2008, 12:48:17 pm »
Question #1
You could have Mamewah launch this app for you, when it starts up. Edit mamewah.ini, and set:
startup_app_commandlines c:\wingun\wingun.exe -m{nowait}
Edit: added {nowait} to the above
Question #2
I think I read that there are some problems with guns & recent versions of Mame, you could have a look at the MameWorld forums...
« Last Edit: March 08, 2008, 12:51:06 pm by Minwah »
Haggar
  • Last login:February 13, 2017, 05:12:32 am
« Reply #6 on: December 04, 2008, 09:38:32 am »
Same problem here. Have you solved in any way?
