Main > Everything Else
Need some XML help
ChadTower:
What is it written in? That's where I'd look... into the source code to find where that XML is being generated.
boykster:
--- Quote from: ChadTower on August 29, 2007, 10:35:58 am ---
that's what I'd do to, but not everybody is a software developer :D
ChadTower:
A decently written app will usually have enough commenting in a text parsing routine to be able to tell what it's doing, even if you don't understand quite how. If it's in a scripting language, that is.
shmokes:
I'm almost positive that it's PHP. I'd have to go back to the site and look again to be sure. But, on the other hand, it's not the actual program that matters so much here as the desktop side programs that can generate photo galleries with thumbnails, such as the Picasa template or Photoshop script that I have. Those could be written in anything (and the two clearly are written in different languages) so long as either one of them produces a folder with thumbs, a folder with images and an XML file pointing to them with all the proper syntax or wording or whatever you programming people would call it.
Anyway . . . I just got home so I'm going to give these suggestions a go and then report back.
shock_:
--- Quote from: ChadTower on August 29, 2007, 01:04:34 pm ---
No guarantees the comments are in English either, though :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
