Main > Project Announcements
The Avrus Arcade Project "Conquest" [4 player, 3 TB, 2 spinner] (WiP)
Pages: << < (10/13) > >>
ids:
awsome - how about robotron, or two-player smash-tv, etc?  And where can I download (making some assumptions here) your plans?
Avrus:
--- Quote from: ids on January 29, 2008, 09:02:20 pm ---awsome - how about robotron, or two-player smash-tv, etc?  And where can I download (making some assumptions here) your plans?
Haven't had a chance to configure the two joystick thing, will tackle that this week.
I'm just double checking the control panel measurements because I did things backwards (and it's cost me).   I laid out the panel and then made the template afterwards, so it's taken 3 print jobs to get it exact.  Need to print one last one to ensure it's all within 1/16".
The cabinet itself is pretty much straight from Saint's book, just modified with a 2x4 frame on the inside.
ids:
Thanks - most interested in CP layout, as I plan on basically following the UAII from saints book for the cab.  If all 3 TB's are accessible and easy to use, and its good for 2player smash-tv, then you've got a winner in my books (and a copy-cat in waiting here)
Avrus:
Well I've been busy.    The cab has gone through some serious play testing, and it's clear that setting up all the games with all the controls is going to take some time.
The trackballs had to have the y wires reversed, as it was functioning like a flight stick.  Down was up and up was down.  Easily fixed by reversing the outside wires that plug into the Mini-PAC.
It's alive!   A beautiful sight indeed.
Here's Dragon7x playing some track and field.
Here's Canuckle playing some track and field.
The camera doesn't do justice showing off the greylite #14 glass.  It's dark.  Very very dark.
Had to load up joust, because it's a classic.
Here is the glass outside of the cabinet.
Spent 2 days applying bondo, priming, sanding and painting the control panel box.  It looks significantly better if you check out some of the older pictures.
Nice curves to it now.
The admin panel, waiting for the paint to try so I can install it.
The diamondplate came in, after I ended up going to the FedEx depot to pick it up.  FedEx claimed they attempted delivery, yet no truck appeared in my parking lot and no one rang the door bell.
Tomorrow I'll take pictures of the work I've done mounting the computer onto the wood panel.  I'll also take pictures of the admin panel mounted, with the cool illuminated Bulgin Vandal power switch.
Also, the cab has a name;
Conquest.
I've attached an image of my control panel layout.
Avrus:
So I took the admin panel from J's garage and brought it home to mount the buttons. I originally went out looking for a 3/4" nut for the Bulgin Vandal power button. I should have been more observant, because it already comes with a half height 3/4" nut on it.
Lots of driving around wasted on that.
After mounting the admin buttons and the power button the paint ended up getting scuffed up, and the paint had some indents in it from behind handled.
Sanded it with a 120 grit sand paper, put a few more coats of enamel paint on it (after taping off the buttons. It's now nice and shiny.
Very difficult to get a good shot of the button. The button doesn't come with the 'power' symbol on it, I ended up getting a sheet of vinyl decals from Pondo in the BYOAC forums. I'm very happy with the results.
I had originally planned on 2 inch spacing between the buttons, but I was concerned about the vinyl labels overlapping. I increased it to 3 inches and I'm very happy with the results. All the buttons are vertically aligned and the net resulted is a very appealing look.
J came over to look at the progress I was making, and I managed to leverage him to help me install the glass. The L brackets I was using were too large, so we ended up putting a slight bend in them so they wouldn't cover the control box bolt holes.
I'm very pleased with the results. The glass, as you can see, is quite dark. It adds that missing element of 'arcade feel' to the cabinet.
The challenge with taking a picture with a dSLR is that it's constantly trying to increase the light levels. The net result is light reflections off the glass, when in reality there is very little reflection at all.
Here is the heart of the machine. Motherboard on a Lian-Li motherboard tray, with a Vantec hot swap drive case, and the power supply. I used some beefy panel clamps on the top and bottom and they hold very securely.
Another angle.
I need to practice taking more shots with my camera. This is with the ISO turned up and the flash turned off. The effect doesn't quite come out like I wanted, but you get the idea.
This is the back of the control box with the admin panel securely mounted. I used 4 x 1-1/2" L brackets.
A picture inside with the motherboard mounted securely. Looking much more tidy now.
The admin panel serves to fill the gap at the top of the control panel, and add that little bit of polish.
I can't wait to see the control panel with some artwork applied.
My Pac-Man 4-way reunion stick came in. Now I can mount it, and use it on the games I need to, rather than trying to struggle with an 8-way.
Unfortunately the mount is slightly different from what I had routed. As you can see there's some damage to the wood that requires some bondo to repair.
I finished the afternoon by taping the underside and applying bondo liberally to fill the holes and the notched areas. I'll drill new holes tomorrow, and securely mount the 4-way.
Go to full version
