Main > Main Forum
Ball replacement stick for P360
Pages: << < (2/3) > >>
jdjuggler:
Homebrew -
What joystick did you put the ball top handles on?
Homebrew:
P360
-Kevin
bdsjake:
anyone know where I can get a GREEN ball top?  I really want this color.  Found a couple of japanese websites with green balltop joysticks, but I have no idea how to order.
thanks,
OSCAR:
When I needed a green balltop for this project, http://www.skum.org/bartop, this is what I did:
I took a blue Wico balltop that I already had and scuffed it up with steel wool.  Next I coated it with primer that was formulated for use with plastic, it was made by Kilz, IIRC.  Then I just spray painted it with about 3-4 color coats and finished it off with about a dozen clear coats.  It turned out great!  Even after countless hours on this joystick, it still looks just as good as when I finished it.  I figured I might have to refinish it after a while, but even after a couple years it has held up great.  I doubt now that I will ever have to go back and refinish it.
MrToasty:
--- Quote from: bdsjake on May 12, 2003, 12:24:17 am ---anyone know where I can get a GREEN ball top?  I really want this color.  Found a couple of japanese websites with green balltop joysticks, but I have no idea how to order.
If all you need is the replacement handle and not the whole joystick, contact the guy mentioned above.  I have two green Wico replacements from him.  If you need Happ replacements, he makes those as well.
Go to full version
