Main > Main Forum
Anyone use COLORED bolts?
Pages: << < (2/4) > >>
shmokes:
The last time I went to an arcade I saw few, if any, cp's that had bolts showing aside from one in each corner of the plexi.  There were only about 8 or 10 games or so as it was just a little movie theater arcade, but...
I wasn't planning on using plexi, though, for better or worse.  I'm planning to laminate my control panel with a brushed aluminum laminate and not planning to use artwork on the panel.  I know, blasphemy, yada yada yada.... I'll just have to rely on the buttons and sticks themselves as a counterweight to the otherwise flat plain issue.
Question, though:  If I need to remove the stick can't I just pull the nuts off and remove them from the bottom...carriage bolts remaining in place?  I've never mounted a joystick or buttons yet.
BillyJack:
huh huh... you said "pull the nuts off..."  huh huh...
sorry, nothing to add here, just being an ass.
mpm32:
I used bolts like the skateboard ones shown.  They weren't actual skateboard bolts but work the same.  I don't see why you can't just remove the nuts - the bolts stay in place, take off the joy, do what you need to and replace it.
You're supposed to do whatever you want to your panel.  I didn't want bolts showing at all on mine and I think it looks great.  I did it, even though I wasn't supposed to.  The buttons hold the lexan down fine.  I hope the BYOAC police don't get me.  Also, I left it black under the lexan, used nice plain black sign vinyl.  I'm also on the run from the artwork police.  I'll have to go into witness protection soon.
"This is the BYOACP. Come out with your hands up.  You're surrounded.  We know you have an illegal unbolted, unadorned control panel in there.  Put down that joystick and give yourself up.  If you do, you'll be reformed and live to play another day"
Howard_Casto:
--- Quote from: shmokes on April 29, 2003, 11:02:44 am ---
Yes but here is what is going to happen. One day you'll be removing/reattaching a stick and happen to hit a bolt a little crooked.  Bam! nice big crack in your laminate.  Also you are then dedicated to that layout and can never change it.
Distortion:
ahhh...the memories...I remember how cool it was when lucky came out with the green bolt to help you distinguish the front of your board from the back!  I had a set of those on mine; they were rad.
Go to full version
