Author Topic: translucent and illuminated ball tops  (Read 7375 times)
SavannahLion
« on: August 23, 2007, 11:05:20 pm »
Is SlikStik the only company that sells Illuminated Balltops?
It's a cool product and the white would go perfect with a cabinet idea I'm tossing around, but I'd like the option of controlling which color is lit. So a person either has to permanently settle for one color or a balltop that cycles through all of the colors.
Googled around elsewhere, but didn't see any other offerings.  :dunno
genesim
  • Last login:April 12, 2010, 08:18:42 pm
Re: translucent and illuminated ball tops
« Reply #1 on: August 24, 2007, 02:58:38 am »
It funny you mentioned that because I was thinking the same thing today.
The problem I have with the any aluminum/steel joystick(that is completely) is that it tends to be too heavy.    I got them at one time, only to quickly get rid of them.   Not only did they have at least some wobble, but they also were incredibly too tall.
For me, a arcade stick should have a lighter feel, and the grip just feels right with plastic.
Now I do understand the tops are plastic, and having no experience with the light ups..they seem to be better, but it still feels a little "busy" for me.
So I guess I am not much help, but my experience does come from the aluminum alloy that SlikStik sells, and I am sure these are along the same lines.
« Last Edit: August 24, 2007, 03:06:38 am by genesim »
SodaPopinksi
  • Last login:November 09, 2011, 03:38:29 pm
  • Cold, Smokey, Rich Diet Caffeine Free Coke
    • John Keeler
« Reply #2 on: August 24, 2007, 06:14:04 pm »
http://forum.arcadecontrols.com/index.php?topic=52509.0
Someone modified their Slikstik balltop with an RGB led here, however I couldn't find any pics of the final result. Another company that may produce illuminated balltops is Seimitsu. Per from Akihabarashop.com posted a picture of the translucent LB-39's with led attachments but they aren't in production yet. I also remember reading that RandyT from GroovyGameGear may consider offering some illuminated RGB balltops.
"Seimitsu LB-39's make me thirsty"- SodaPopinski
SavannahLion
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
« Reply #4 on: August 24, 2007, 07:29:05 pm »
  I was also considering making a batch of handles. I was originally inspired by the modified Slikstik post (to avoid ordering from Slikstik.) They have a price that is tough to beat. I think that there is a little room for further development (more bases supported etc.)
 Cornchip.
SodaPopinksi
    • John Keeler
« Reply #5 on: August 25, 2007, 07:11:04 pm »
Wow those bat tops look sweet, yeah there is definitely room for other bases, I'd love to have U360's/Sanwas that lit up :)
Cornchip
« Reply #6 on: August 26, 2007, 10:33:32 am »
  The Sanwa's could be modded to LED's as easily as the Happs. The U360 is another case. The circuit board on the bottom would prevent the use of a jack at the bottom of the shaft. Maybe there's another way.
 I'd like to get my hands on a pair of Sanwa JLF's to mod. Anybody know the shaft diameter thru the base?
 Cornchip.
Kaytrim
  • I'm too nice a guy
« Reply #7 on: August 26, 2007, 10:53:00 am »
I hope this helps cornchip  ;D
Cornchip
« Reply #8 on: August 26, 2007, 11:15:54 am »
  Great diagram Kaytrim. That's just what I needed. Thanks!
 Comparing the Happ's to the Sanwa shaft, I can say the shaft diameter's on the Sanwa's are 3mm smaller at the circlip end. That would be to small for the jack I mounted on the Happ's (it had a 8mmx1 thread).  I could however  thread the end of the shaft with a 7mmx1 thread (external) and make a separate threaded bushing to adapt the larger jack (3.5 mm female). Another option would be to locate a 2.5mm 4 pole female jack and see what size thread it uses. Hopefully it would turn out to be 6mm (1/4 inch).
 Cornchip.
Kaytrim
« Reply #9 on: August 26, 2007, 11:37:52 am »
I tried to figure out the threads on the shaft but my tool and die set didn't match up well.  Ask Numski, he should know he makes custom ball tops for the Sanwa sticks.
TTFN
btw the ball top that I have is 35mm in dia, they also have a 30mm ball and bat tops.  Semitsu makes a 30mm, 35mm and a 45mm ball top that fit the Sanwas.  So you have your choice of types and sizes.  :)
« Last Edit: August 26, 2007, 11:55:21 am by Kaytrim »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #10 on: August 26, 2007, 01:15:59 pm »
ooh and ahh.    :cheers:
Keep it going!
Kaytrim
« Reply #11 on: August 26, 2007, 01:46:15 pm »
Cornchip,
One other thing, the groove at the base of the stick is for an E ring and is about 1mm deep  That E ring keeps the inner mechinisims together because they are loaded with a spring.  I'll try to get you an exploded view of the innereds but it will be late tonight.
TTFN
Cornchip
« Reply #12 on: August 26, 2007, 10:43:22 pm »
  I think I'll message Ponyboy in the next day or two to get my Sanwa JLF-TP-8YT stick(s). From there I'll build a 'mini stick' project with the spare parts left over from Revolver (using RGB Led's). Look's like I've got a project!
 Cornchip.   ;D
Kaytrim
« Reply #13 on: August 26, 2007, 10:46:07 pm »
You might want to make a bunch of them with single color LEDs.  You could probably make a mint with them. ;D  I know that I would want a green one.
TTFN
SodaPopinksi
    • John Keeler
« Reply #14 on: August 27, 2007, 01:35:28 am »
Yep that'd be awesome, curious, can you make lighted balltops in addition to bat tops?
fjl
  • Pixels Rule!
« Reply #15 on: August 27, 2007, 05:19:27 am »
I would love to see the U360's have illuminated bat tops. And I think its possible it would just require modifying the metal stick. Drill a hole in the middle and have a wire go through it but not from the bottom but from the side within the enclosure. It can cause problems though like the wire getting in the way of stuff and simply wearing and causing an open in the wire after some use, but I believe it can be done.
Cornchip
« Reply #16 on: August 27, 2007, 07:20:36 pm »
   The 360 will not likely ever happen...here's why. The handle of most joy's that I've seen are free to spin while assembled. If it didn't spin, it would restrict movement. That's why the original design by Slikstik used an audio jack to create a rotary contact (great idea!). That jack must be on the center line of the axis of rotation (at the bottom of the shaft). If the wires went out through the side of the shaft...they would inevitably become wound up and restrict the free movement of the joystick. I think it's a done deal....no 360.   :P
 For Soda...I have made Balltops. As others here, my preference is the Battops for upright cabinets. Balltops would be better for Cocktails and Mini sticks. Just my two cents. I'm not restricted to a single way of thinking.  :D
 Cornchip.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #17 on: August 27, 2007, 09:53:11 pm »
I plan on getting a pair of 360s.  I'd bet you could figure it out.. you know you wanna  :D  pretty please? lol.  When you do, I'd take 2 green balltops.
-csa
SodaPopinksi
    • John Keeler
« Reply #18 on: August 28, 2007, 12:28:36 am »
I was looking at the u360 just now and yeah it would be no small feat to illuminate it, not only does the bottom magnet interfere with things, but there's a lot going on above it too, actuator... spring... The only thing I could think of was to maybe have a section of the lower shaft that spins independently, where you would then drill a hole in the side of it for... well... something like this:
But even if you managed to do something like that there's the actuator and spring in the way of things too.
Btw that ball top looks excellent :)
SavannahLion
« Reply #19 on: August 28, 2007, 01:13:45 am »
Slip ring
fjl
  • Pixels Rule!
« Reply #20 on: August 28, 2007, 03:45:00 am »
Is slip ring those rings that spin with the wire contact kind of like a bearing? I'm sure that could be implemented.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #21 on: August 28, 2007, 09:19:14 am »
With the U360s I would put the audio jack in the bottom of the joystick just like slikstik does and mount the magnet to the bottom of the audio jack.  You would of course have to extend the mounts for the pcb but that shouldn't be too difficult.
Green Giant
« Reply #22 on: August 28, 2007, 09:36:27 am »
It is really quite easy.  Just drill out the top of the shaft.  Insert a fuel cell powered led, and you are set with a light for a month or two.
Toxic Arcade, my first build
Cornchip
« Reply #23 on: August 28, 2007, 04:23:43 pm »
   Unfortunately I don't have a 360 and doubt that I'll have one anytime soon. I agree that it could be done with money and time (I have the time...but not alot of spare money  :-\). I'll stick to the more basic styles for my needs. Is the U360 really that good?
 Cornchip.
« Last Edit: August 28, 2007, 04:27:09 pm by Cornchip »
Kaytrim
« Reply #24 on: August 28, 2007, 05:56:42 pm »
There are a lot of people that like the U360 over any stick out there due to the versatility.  personally I like the 49-way sticks with the encoders from GGG.  It is basically the same just not as fine in the control ability.  The U360 is true analog but is restricted to a 9x9 grid where the 49-way is a 7x7 grid.
TTFN
SavannahLion
« Reply #25 on: August 28, 2007, 07:39:08 pm »
Pretty much. But, it doesn't look like anyone is jumping on the idea.  :dunno
I've got a couple of ideas with different types of slip rings that might work. but eh.  Maybe when I actually get a hold of a 360, I could try them out.
Cornchip
« Reply #26 on: August 28, 2007, 08:58:52 pm »
   When I think of a slip ring, I think about brushes on a commutator. I was wrong. I went to Wikpedia for a start. The difference is a slip-ring has liquid Mercury to make the connection instead of a brush or contact. The challenge is can we find one with up to 4 contacts (RGB) and cheap enough (and that can fit without adding a detrimental amount of length. Stay tuned.
 http://en.wikipedia.org/wiki/Slip_rings
fjl
  • Pixels Rule!
« Reply #27 on: August 28, 2007, 09:33:32 pm »
Mercury! Hey I never even thought of that. It should work pretty well and never wear out. Kudo's to whoever came up with that.
 :notworthy:
I'd gladly sell my u360 for one that comes with an RGB. Take that into consideration, whoever makes the U360's. Now if they only made a turbo twist2 with an RGB and light guns with RGB's in them, my CP arcade would be complete!
« Last Edit: August 30, 2007, 12:17:15 am by efjayel »
SavannahLion
« Reply #28 on: August 28, 2007, 09:55:29 pm »
Oi, people need to stay away from Wikipedia. When you get enough money to buy the mercury slip ring, come back and let us know how it worked for you.
If you're like me and more interested in a true BOYAC solution, try Google instead. You get better information and better ideas that way.
edit: fixed url code
« Last Edit: August 29, 2007, 09:17:33 pm by SavannahLion »
Cornchip
« Reply #29 on: August 28, 2007, 10:00:21 pm »
 Yeah...I think cost is an issue here. There's just no way you'll find an affordable slip ring. I've looked around a bit....and it's not looking good.
 Cornchip.
SavannahLion
« Reply #30 on: August 29, 2007, 09:36:28 pm »
Is there a part sketching or some such to get a better idea of how the U360 is constructed?
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #31 on: August 30, 2007, 09:44:38 am »
if'n you dont want your wires tangled up underneath do to the stick spinning around(eventually it'll happen) you may consider a cheap solution like a twist-free phone cord jack. I'd check places like dollar stores/biglots/etc. Staples thinks they need to sell an item like this for $3, but if you look hard enough .59 is very doable.  :cheers:
Kaytrim
« Reply #32 on: August 30, 2007, 09:53:53 am »
aww crap, forgive me, i modified the wrong post. Didnt mean to intrude on this one sorry and i fudged your reply. Sorry bout that one kaytrim.
« Last Edit: August 30, 2007, 05:55:29 pm by NIVO »
SavannahLion
« Reply #33 on: August 30, 2007, 01:38:31 pm »
Does the fact the U360 spin have some sort of gaming functionality? I don't see it mentioned anywhere on Ultimarc website.
Kaytrim
« Reply #34 on: August 30, 2007, 02:39:40 pm »
No it serves no functionality but smooth out the movement of the stick.  If you have played with a stick that is fixed, no rotation, it is more difficult to get the directions exact.
TTFN
SavannahLion
« Reply #35 on: August 30, 2007, 04:12:17 pm »
Can't say that I really ever noticed. I tended to hook my paw or palm it depending on how slick the stick was. :P
Cornchip
« Reply #36 on: August 30, 2007, 04:46:52 pm »
    Thanks NIVO for the suggestion. I can't guess at the durability of the twist free jack....but it is a great solution to get 4 conductors thru the base of a handle (if all 4 are supported...might be only 2 conductors). A problem might be integrating  the jack due to it's odd shape. Still....I wouldn't mind seeing one of these jacks with my own eyes.
 About the U360....you can pretty much forget about it as far as development in this thread. I don't mean to sound harsh and I apologize if this upsets some. This time around for my uses...the Sanwa JLF was to be my interest. But what applies here can apply to other bases. The U360 really is another story due to the unconventional design. Sorry.
 Cornchip.
« Last Edit: August 30, 2007, 05:06:57 pm by Cornchip »
Kaytrim
« Reply #37 on: August 30, 2007, 05:55:15 pm »
I don't know how many of the JLF lighted tops you were thinking of making but there could be a real calling for them over at http://forums.shoryuken.com/index.php.  They use the JLF quite a bit for custom sticks.  I know that I am interested in at least one for myself if not for the custom sticks that I plan on building for others.  These would be single colors anyway no need for the RGB LEDs in these.  The voltage is 3.3v IIRC off the pads that get hacked.
TTFN
Kaytrim
NIVO
« Reply #38 on: August 30, 2007, 06:00:50 pm »
again didnt mean to fudge that post above kaytrim. I should've clarified my position further as I didnt mean this as a solution to the U360, i know full well the stick and its hinderance to modify. I was posting alternate info to use as a solution to other sticks. It does indeed work, but you'll need space beneath as this makes it a "tall order" to implement.
SavannahLion
« Reply #39 on: August 30, 2007, 06:13:56 pm »
Cornchip, I can't vouch for everyone else. For me, it has more to do with increasing the available options. It's not necessarily about specifically having a U360 light up.
