Main > Everything Else
i have a new understanding of the mcdonalds coffee case now
billf:
--- Quote from: pinballjim on August 23, 2007, 02:54:46 pm ---McDonald's was using super cheap coffee and found out that serving it hotter made it smell better. The people making this decision knew that the temperature was dangerous. It was much hotter than any coffee pot you have at home brews your coffee and much hotter than any other restaurants serve it at. (remember, this is a fast food, eat it in your car while you're driving type of restaurant, and the coffee was undrinkable for several minutes)
Where are you getting this from?
From the wiki article:
Home and commercial coffee makers often reach comparable temperatures.[16] The National Coffee Association instructs that coffee be brewed "between 195-205 degrees Fahrenheit for optimal extraction" and consumed "immediately". If not consumed immediately, the coffee is to be "maintained at 180-185 degrees Fahrenheit." [17]
ChadTower:
Someone put something odd in there and we'll see how long it takes to get it off. Something about her having herpes that was burned off by the coffee so she actually benefitted from it.
ChadTower:
I don't see anything like that in there.
--- Quote ---# (cur) (last) 19:25, 23 August 2007 THF (Talk | contribs) m (17,356 bytes) (Reverted 1 edit by BillDritz identified as vandalism to last revision by Cool Hand Luke. using TW) (undo)
# (cur) (last) 19:25, 23 August 2007 BillDritz (Talk | contribs) (17,525 bytes) (→Evidence presented to the jury) (undo)
Maybe it got whacked by a parser?
ChadTower:
Okay, WTF... three minutes? Are people seriously watching this that closely?
billf:
--- Quote from: pinballjim on August 23, 2007, 03:16:46 pm ---1 - get off of wiki
2 - http://www.lectlaw.com/files/cur78.htm
3 - "coffee served at home is generally 135 to 140 degrees"
If you think there isn't someone at the McD's corporate office monitoring that wiki page, you're nuts.
The link above is good. Much better than the wiki. Thanks for posting it.
--- Quote ---McDonald's was using super cheap coffee and found out that serving it hotter made it smell better.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
