Author Topic: u360 question  (Read 1070 times)
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
u360 question
« on: August 19, 2007, 08:46:18 am »
There is an optional hard spring and restrictor plates for this joystick.  Are both really necessary, or could I get by with say just the spring or just the restrictor plate.
Also the restrictor plates come in 4-8 way and circular.  What would the circular one be used for?
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
Re: u360 question
« Reply #1 on: August 19, 2007, 09:40:35 am »
The circular restrictor shortens the throw, but doesn't otherwise change the feel (i.e. still no corners).
The rest is basically personal preference.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
ARTIFACT
  • Last login:May 30, 2018, 12:32:23 am
Re: u360 question
« Reply #2 on: August 19, 2007, 01:06:23 pm »
i asked the same thing and basically it's all personal preference...
I bit the bullet and just ordered Medium Springs + Restrictor kits ... I'll see if/which I use when I try them for myself.
stephenp1983
Re: u360 question
« Reply #3 on: August 19, 2007, 06:38:04 pm »
Let me know what you think when you get yours together.
Lakersfan
  • Last login:February 05, 2024, 12:16:07 am
Re: u360 question
« Reply #4 on: August 19, 2007, 07:59:30 pm »
Ditto. This is my next step while waiting for the paint to dry and U360's are my joystick of choice. I haven't had experience with other joysticks around this site - just the ones I knew as a kid... ;)
Artifact - In case you haven't noticed yet, I'm about one step behind you. So I'll probably join you in alot of your threads!
stephenp1983
Re: u360 question
« Reply #5 on: August 19, 2007, 08:06:57 pm »
I went ahead and ordered the springs and the restrictors 14 dollars shipping for a little package lol :)
SGT
  • Last login:April 17, 2023, 08:29:42 pm
Re: u360 question
« Reply #6 on: August 19, 2007, 08:11:16 pm »
Does Ultimarc not allow you to choose the desired spring when you order the U360? ???
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
Re: u360 question
« Reply #7 on: August 19, 2007, 08:27:16 pm »
if you have not done so already i recomend the longer handles as well.  the standard ones are too short if you are using 3/4" mdf
ARTIFACT
Re: u360 question
« Reply #8 on: August 19, 2007, 08:37:09 pm »
Correct! make sure you order the longer shafts if you mount on 3/4" control panel board... that's what I ordered as well (from Divemaster127)
Haha yes I read your post and thought I had just posted this too :)
Where is your project thread?
stephenp1983
Re: u360 question
« Reply #9 on: August 19, 2007, 09:39:54 pm »
I didn't order the longer shafts, as I want to see how it feels with the standard ones.  I like the shorter feel for some reason, kinda like the doa 4 stick I have.
fixedpigs
  • Last login:June 05, 2022, 04:56:10 pm
  • warning: drew can't handle my avatar...
Re: u360 question
« Reply #10 on: August 19, 2007, 11:27:04 pm »
nope...which is really too bad...the extra cost is one of the reasons i've still been waiting on randy's sticks to come out...
had i been able to customize the spring from the start...i'd have gotten the u360s a long time ago...
ARTIFACT
Re: u360 question
« Reply #11 on: August 19, 2007, 11:36:30 pm »
same with the restrictors... it's not possible to order say... a U360 + Circle Restrictor ... you have to pay for all the restrictors.
It's not THAT expensive, but it all adds up!
SGT
Re: u360 question
« Reply #12 on: August 19, 2007, 11:59:39 pm »
I may have dreamed this but I thought that Andy with Ultimarc had said once his inventory of weak springs went down somewhat, he would give a choice of springs.  Didn't he say that last year sometime?
fjl
  • Pixels Rule!
Re: u360 question
« Reply #13 on: August 20, 2007, 12:40:37 am »
Would of been nice cause I had to pay extra for the harder springs. IMO The hard springs make a world of difference but yet, I would still like them to be even harder.
