Main > Main Forum
What joysticks do you prefer and why?
Pages: << < (4/7) > >>
Wienerdog:
--- Quote from: OSCAR on April 28, 2003, 09:47:32 pm ---My new favorite joystick is the Happ P360 (http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=6294;start=0) with 4" Wico balltop handles.  This is an expensive route to go, but now that I've used them I won't use anything else.  The Wico 8-way leafs are also good and I have used them in various projects, but they don't even compare to the feel and accuracy of the balltop on the Happ P360, IMO.
Sure, rub in that DOT spinner...
Can I get the 4" Wico Balltop handle by itself somewhere or do I have to buy the joystick?  Where is the best place to buy that stick?  Is that one of the Universal Series 500 sticks at http://www.wicothesource.com/new2/pages/page88.htm ?
OSCAR:
--- Quote from: Wienerdog on April 28, 2003, 10:24:19 pm ---Sure, rub in that DOT spinner...
You don't want that one, it's the prototype and not as high quality as the production ones.  I opted to keep that one for myself, you guys will get the good ones...
--- Quote ---Can I get the 4" Wico Balltop handle by itself somewhere or do I have to buy the joystick?  Where is the best place to buy that stick?  Is that one of the Universal Series 500 sticks at http://www.wicothesource.com/new2/pages/page88.htm ?
No, do not buy the Series 500 for swapping out the handle, it is actually a Suzo 500 and not the same as the old Wico balltops.
www.arcadeshop.com has the 3.5" handles in stock, I don't know if they carry just the 4" handles.  Watch eBay for new/used Robotron sticks to get a 4" handle.  I bought a bunch when www.videoconnect.com still sold them.  I'm not sure if the Wico microswitch joysticks used the same handle or not, perhaps they are compatible as well.   ???
armad1ll0:
I totally am into the J-Stick which is an odd term for just a Japanese stick. The one on Ultimarc is a Sanwa but the Seimitsu is pretty much the same. I'm building one out of the Sanwa right now.  See my site for my Capcom FP mini Stick...
I had to swap ball tops to get the blue one on there. I have another 4 Seimitsu's ready to go into desktop control panels. For my ArcadePC, I have four Oval/Bat top Sanwa's waiting for the control panel when I get to it.
wee beastie:
Another vote for the j-stick here too!  I wrote up a semi decent sized review of it awhile back on this message board.  Dig around and you may find it.
The main good points
1-restrictor works great and allows you to easily switch between 8 and 4 way.  There are no kinks when moving from one cardinal direction to the other, just a smooth slide down the restrictor
2- ball top, no explanation needed.
3- I didn't route my 3/4 inch control panel and when I installed the stick, it's about the same height as a Ms Pacman joystick (this is the effect I was originally going for)
Only negative point is that the j-stick is very loose.  Pac sticks (originals) were a little tight.  You really had to try to push in a direction.  The j-stick spring is so light, simply resting your hand too much on the stick will push it in a direction.  But, really, you get over that pretty easily.
m3talslug:
I love my P360s!  I like my Supers second best.  I never really liked joysticks with a Square feel.
http://tobywong.50megs.com
Go to full version
