Author Topic: Mortal kombat 4 Help...Faulty Board??  (Read 1685 times)
SUPER_SSII_TURBO
  • Last login:September 17, 2007, 01:33:52 pm
« on: August 17, 2007, 07:53:38 pm »
Hi I have just put...or attempted to...put a mortal kombat 4 pcb in my street fighter II cabinet...basically with the mortal kombats and street fighters, the only only wiring differences is the kick harness, se easch requires their own...but that is only for the 3 additional kick buttons....
Anyway here is whats going on...(i dont have the kick harness yet for the mk4 board) i plug in the board all the roms check and are fine...but the standard buttons that should be working(normal jamma boards are 3 button based) are not working...plus my screen gets waves in it...the street fighter board runs flawlessly whith this monitor..and it should not make a diffenrence...its a 25 in. standard res monitor...which is what both these games originally played on...any help would be great as i just spend 200.00 on this PCB board. and im lost
thanks
BobA
  • What Me Worry?
Re: Mortal kombat 4 Help...Faulty Board??
« Reply #1 on: August 17, 2007, 08:14:38 pm »
Maybe the 5V adjustment on your power supply.   Some boards require more power then others and can drag down the 5V if not adjusted.
SUPER_SSII_TURBO
« Reply #2 on: August 17, 2007, 08:23:54 pm »
waw that might be...ut umm where would i find this wonderfull adjustment...thanks...anysuggestions on the buttons not responding..thanx again
SUPER_SSII_TURBO
« Reply #3 on: August 17, 2007, 08:36:19 pm »
i looked all over my power supply i cant seem to find an adjustment
RichSorr
  • Last login:August 29, 2015, 07:27:00 pm
« Reply #4 on: August 21, 2007, 12:29:19 am »
what kind of power supply is it? It's usually just a small pot on the side
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:May 04, 2024, 09:08:32 am
« Reply #5 on: August 22, 2007, 09:29:45 pm »
Thread rebooted. No bickering or I break out my... um.... well... it'll be something spectacular, yeah!
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #6 on: August 22, 2007, 09:30:55 pm »
That sounds vaguely dirty...
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: August 22, 2007, 09:34:36 pm »
Same topic, same OP, but two different threads ... other thread is here:
http://forum.arcadecontrols.com/index.php?topic=70302.0
Working: Not Enough
Projects: Too Many
Progress: None
