Main > Main Forum
Router Question and Quick-Disconnect Q
JoyMonkey:
--- Quote from: HeadRusch on April 29, 2003, 06:45:21 pm ---Yep, Bob confirms..just squeeze and go. the $8.00 soldering set I bought may remain untouched.
So what crimping tool did Bob suggest? I've just been squeezing them tightly with a pliers. Seems to work just fine, but maybe with time the connection might loosen???
Smittydc:
The one andy sells in his wiring kit http://www.ultimarc.com/controls.html is pretty standard and I'm sure you can pick one up at Radio Shack, Home Depot, or any electronics store.
[actually, I'd like to give a big positive review to that wiring kit. I wasn't sure I wanted it for the $$ when I ordered but the wire is the perfect guage and in multiple colors, it took several CPs to use that many connectors, and I needed a decent crimper anyway. I've since tried to buy similar wire and connectors all over town and they aren't easy to find or cheap. Thanks Andy!]
HeadRusch:
Just the one he sells...it was only about 18 bucks i think, I said "sure, why not".....I needed the tool anyhow so...we'll see how it works out.
