Author Topic: Electronic Help Needed ***  (Read 883 times)
koolmoecraig
    • My Intervention
« on: August 14, 2007, 08:12:48 pm »
I have one of those little electronic boxes that says pre-recorded stuff when you press a button.  Kind of like those talking greeting cards.
Anyway, I was wondering if it would be possible to increase the volume by simply installing a bigger speaker or would I have to increase the voltage as well?  It currently runs on two AA batteries.
I'm pretty much an idiot with stuff like this.
What's the easiest way to so this?  Basically, I want to add some sort of amp to it.
koolmoecraig
    • My Intervention
Re: Electronic Help Needed ***
« Reply #1 on: August 14, 2007, 08:15:08 pm »
This is for an arcade machine.  I'm going to wire it to trigger when you insert a quarter.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 15, 2007, 10:27:07 am »
In general, a bigger speaker may or may not help. If the speaker was more efficient (a.k.a. "sensitive") you'd have more volume.
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
« Reply #3 on: August 15, 2007, 10:36:14 am »
Basically, you'll want to add some sort of amp to it :)
Ok, the long answer.....you should be able to actually connect a mini-phono plug in place of the speaker and plug it into your PC's aux audio in.  The levels might not be correct though, and may need an extra resistor somewhere to bleed off some of the output if it is too "hot."  From there, use the mixer app to get the volume where you want it.
But don't be surprised if it doesn't sound all that good once it's amplified :)
RandyT
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« Reply #4 on: August 15, 2007, 01:34:30 pm »
I'm wondering if you'd have better luck
1) making a recording of the sounds,
2) cleaning them up/amplifying them with some sound editor program, and then
3) using software on your PC to trigger the sound when it recognizes a coin input.
I think Goldwave shareware can do (2) at least, if not (1) and (2).
I'm sure it wouldn't be too hard to write a program to do (3) and have it map to key inputs that you'd hook up.  I bet I could write (3) if you get really stuck...
SavannahLion
« Reply #5 on: August 15, 2007, 02:03:28 pm »
What about Audacity? I taught my GF some of the basics. She uses it, along with another tool, to resample and crop MP3's for her cell phone. If I have to hear Fergalicious one more time, I think I'll crack.  :banghead:
