Main > Everything Else
IR Repeater - anyone ever set one up?
ChadTower:
That has a tuner... one spot in that desc says up to 720p but down below it says 1080i. Double check that before buying. I have the 332h myself.
That makes a fantastic gaming monitor and works well as a PC monitor too. I've done both and it's great for each. Makes a brilliant XBMC monitor, reading comics on it is really cool.
Samstag:
--- Quote from: CCM on August 07, 2007, 10:44:29 am ---Has anyone set up an IR repeater and, if so, how well does it work.
The only setup is physically installing it. There's no configurization necessary, at least one the ones I've used. Just plug them in, point them in the right direction, and you're done. I'm not using any now, but I had a set from X10 I was using to control several systems on the other end of the house and never had a problem.
ChadTower:
I had one and got really intermittent results until I figured out that people kept walking in the path of one of the repeaters and blocking line of sight.
boykster:
don't listen to chad when it comes to electronics, he'll just tell you it will break and not be worth the money ;)
My entire house is wired with a custom IR distribution system, so I can give you some real-world advice. I like your idea of having what I call a "zero footprint" AV installation, simply a display hanging on the wall with all the equipment hidden away. It sounds like you're on the right track for getting source cabling to your display (from behind, or run cables thru the wall). It is against code in most if not all cities to run a power cord through an enclosed space, so for power I like to install a recessed outlet behind the display so even the power cord can be completely hidden. I generally install what is known as a clock-hanger outlet
http://www.kyledesigns.com/product/S3713-BK
to give some room for the plug, etc. Not necessary, but adds a finished touch.
as for IR distribution, the best solution is made by a company called Xantech, but there are several good options out there. you basically are going to need a simple distribution block with a single IR target, and multiple emitters (1 for each device you want to control). The emitters are cheap, the distribution blocks are reasonable, but the IR targets can be expensive.
Here's a good inexpensive all in one solution:
http://www.smarthome.com/83608.html
here's a much more expensive kit that includes a plasma proof IR sensor (why its expensive):
http://www.smarthome.com/81206bk.html
here's a similar kit with a standard IR target:
http://www.smarthome.com/8120kb.html
You can shop around and get better prices than smarthome - try worthdist.com but smarthome has a great selection and you can get a feel for how they work. You can also piece together a kit.
I would DEFINATELY stay away from X10 stuff for IR. I use some X10 stuff for PLC based control, but mostly have moved to other branded PLC stuff since X10 is so flaky.
ChadTower:
Someone has to balance boykster's "the solution is to spend $4000 on a setup that can be functionally duplicated for $200". :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
