Main > Main Forum
Considering Trackball & Spinner for my cab... TOP 10 games for each?
u_rebelscum:
--- Quote from: Havok on August 07, 2007, 10:53:40 am ---The TT2 is the ONLY aftermarket spinner that matches Arkanoid's native resolution...
Nope.
The Ultimarc SpinTrk also has a higher res than arkanoid. It's true the TT2 is even higher (1200 cpr vs 1000 cpr), but both are higher than arknoid's (in the nine hundreds).
Change your statement to "... is one of two ..." and you're correct. ;)
RandyT:
--- Quote from: u_rebelscum on August 07, 2007, 12:23:36 pm ---
Nope.
That's correct. However, an accurate statement would be that only the TT2 gives you enough extra resolution to compensate for a change in feel of control that results from using a larger than original equipment knob on a game like DOH, and perhaps other games which use a potentiometer based control.
RandyT
scotthh:
If you get the TT2, you can use the TT2 interface for your trackball (a used 3" Happ perhaps?)
Havok:
Nope.
Ooops - forgot about Andy's.. My bad - you are correct.
Still, the steering wheel option makes the TT2 a more versatile choice, in my mind...
ARTIFACT:
--- Quote from: scotthh on August 07, 2007, 02:57:12 pm ---If you get the TT2, you can use the TT2 interface for your trackball (a used 3" Happ perhaps?)
Ohh that's an excellent suggestion... I didn't know I could do that.
