Main > Main Forum
Will this work as a spinner?
Pages: << < (2/2)
Xphile:
you could cut out the hole for the knob, then chamfer the underside of the hole so it mates with the 45 degree angle of the base of the unit, then epoxy or construction adhesive it into place (or use some kind of backer plate if you want it removeable..:-)
AX:
or for almost the same money you could buy one of oscars and save yourself the hassle.
Pages: << < (2/2)
Go to full version
