Author Topic: need help finding mame.ini  (Read 17461 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: August 02, 2007, 03:40:30 am »
i'm using mamewah v1.62b13 and mame 0.117 Windows command line version from mame.net
but i can't find mame.ini for mame itself (not the one in mamewah but the one in mame folder.)
i even tried creating new mame.ini by typing -cc in command. but nothing happens.
the reason i wanted to find mame.ini is because i wanted to enable mouse support.
i googled up and down the interweb but didn't find any good answer to this problem.
can anyone help me please? thanks!
My website: www.bossyman15.com Lots of arcade pictures inside!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: need help finding mame.ini
« Reply #1 on: August 02, 2007, 03:59:47 pm »
What error did you get?  If you were in the main folder, and typed "main -cc" (without the quotes), it should have created the mame.ini file.
Robin
Knowledge is Power
bossyman15
« Reply #2 on: August 03, 2007, 03:06:48 am »
i got no error of any kind
tell me if i did this right
open run and type CMD to open command window
drag mame.exe into command window
type -cc and press enter
is that way to do this?
i also tried -cc,  mame -cc. -createconfig and so on but nothing
and IF i did create mame.ini where would it be created?
please tell me by step by step on how to do this.
thanks!
Havok
  • Trade Count: (+17)
« Reply #3 on: August 03, 2007, 07:16:49 am »
Sounds like you are not in the correct directory. For example, if your Mame.exe is located in C:\Mame, do the following:
Get to the command prompt, the way you are doing it will work.
Once there, type C: (just to make sure you are on the correct drive letter first)
cd\Mame (to put you in the Mame directory - change to suit your config)
Mame -cc
Done!
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
« Reply #4 on: August 03, 2007, 08:42:17 am »
Or instead of typing mame -cc try typing mame -createconfig.
gonzo90017
« Reply #5 on: August 03, 2007, 11:48:04 am »
Go to http://www.gabrieleponti.com/software/ and download Sendtotoys. When installing the program uncheck everything except command prompt. When you're done just right click on mame.exe and highlight and click on command prompt. Now type configure --cc
bossyman15
« Reply #6 on: August 03, 2007, 11:56:48 am »
Mame -cc
Done!
so you saying i would type F: cd\mame and then mame -cc
is that right?
Havok
« Reply #7 on: August 03, 2007, 02:22:21 pm »
Yep!
bossyman15
« Reply #8 on: August 03, 2007, 03:21:03 pm »
thanks! it worked! now i can use trackball in mame! :applaud: :applaud:
