Author Topic: Speaker shelf (Project Arcade)  (Read 1142 times)
pboreham
  • Last login:June 28, 2008, 04:36:53 am
« on: July 31, 2007, 07:26:19 am »
I've just cut my speaker shelf and when it sits on the securing blocks, it is at an angle to the top of the cab. i.e. the edge of the top of the cab is 90-degrees and the speaker shelf looks about 60-degrees.
Is this normal, or do you have to level the speaker shelf off at an angle so it is at the same angle as the top of the cab (for securing the marquee).
Prob been asked a hundred times but only found one vague reference in the search!
Thanks guys!
Dont Laugh! My first build blog...
http://paulmakescab.blogspot.com
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
Re: Speaker shelf (Project Arcade)
« Reply #1 on: July 31, 2007, 08:18:43 am »
Thanks guys!
If I understand you correctly, it is normal.  It sounds like you are ok.  Here is a picture from my website, maybe this will help...
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
pboreham
« Reply #2 on: July 31, 2007, 08:47:29 am »
Thanks guys!
Cool - how does the marquee work though?!
ChicagoDave
    • Dave's Website
« Reply #3 on: July 31, 2007, 08:51:23 am »
Thanks guys!
I just used a Happ Marquee Retainer and it worked just fine.
Homer Simpson:
pboreham
« Reply #4 on: July 31, 2007, 09:29:24 am »
Thanks guys!
Cool - looking forward to see how that works then!
unclet
« Reply #5 on: July 31, 2007, 09:40:36 am »
This should still work even though your speaker panel is at an angle:
http://forum.arcadecontrols.com/index.php?topic=9978.0
