Main > Main Forum
Now to the control panel... 360's? Advice please!
pboreham:
OK, after some research, I've found out that a spinner with a steering wheel already exists!!! :banghead:
Soooo... anybody know where I can get the TT2 Spinner in the UK? I've seen it on GGG - what are they like for UK based deliveries?
Thanks, Paul.
RobotronNut:
--- Quote from: pboreham on July 29, 2007, 02:36:49 am ---
--- Quote from: Doom bucket on July 29, 2007, 12:59:46 am ---360s are still technically 8 way they aren't analog
I thought they have an analogue range - so I can use it for flight games and racers?
depends on which "360" you're talking about. happ P360's are 8-way digital. ultimarc U360s provide both analog and digital outputs.
pboreham:
It was the U360's - so I guess they are analog?
If I go the spinner route for the driving games, I may not bother with analogues... arghhh! Decisions, decisions!
fatfingers:
--- Quote from: pboreham on July 29, 2007, 04:36:48 am ---It was the U360's - so I guess they are analog?
The U360s are definitely analog-based.
AlexKidd:
The U360 works well for an analog flight stick. It works okay for 270 wheel games although the movement range is sorta short so it can be twitchy. They work very well for super hangon though. With creative mapping in mame and two U360s you can get analog steering, throttle and brake. Even in analog mode mame does a good job of making them work in 8 way games but you can have it load different maps to adjust where the directions activate.
