Main > Main Forum
Quick disconnects
Pages: << < (3/3)
rampy:
--- Quote from: NickC on April 27, 2003, 05:49:08 pm ---The quick disconnects I am using dont hold the wire very well, so I will be soldering the wire to the qd.....
You might have bought/used the wrong gauge wire for your QD's.. but usually the "fold over the wire itself" and then crimp...
Are you using stranded or solid core wire?
*shrug*  Not that there's anything wrong with soldering the QD's to the wire... just shouldn't be necessary...
rampy
Cue-Ball:
How well the QD holds onto the wire also depends a lot on the crimper that you're using.  Some crimping tools give you a lot more leverage than others.  Also, some are shaped differently and don't clamp down as well as others.
Pages: << < (3/3)
Go to full version
