Author Topic: Is it OK to top-mount Mag Stick PLUS joysticks? (flush, inset plate)  (Read 3279 times)
ARTIFACT
  • Last login:May 30, 2018, 12:32:23 am
Do you guys see problem(s) with top-mounting joysticks (MAG STICK PLUS x 2) on my "ARTIFACT CAB" 's CP?
I like the look of the metal plates :) ... and I ordered regular length sticks (red ball) which are it seems for top mounting
Mag Stick PLUS:
Some preview plans of my CP with flush, top-mounted Mag Stick PLUS joysticks (artwork not shown, cab colors not final):
Thanks in advance for your input on this!
Go BYOAC!  :applaud:
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Is it OK to top-mount Mag Stick PLUS joysticks? (flush, inset plate)
« Reply #1 on: July 22, 2007, 03:22:58 am »
unreal
base is larger from mountplante-63,3mm
75mm (lever+terminal microswiteches)
you have to make new wide mountplante, from aluminium
regular it will be too high. Andy sell shorter balltop for metal panel. Battop (III groove 70mm) for metal  panel you will buy only in iL
http://www.industrias-lorenzo.com/g3repository/PRODUCTO/219452F0.PDF
« Last Edit: July 22, 2007, 03:28:09 am by kowal »
ARTIFACT
« Reply #2 on: July 22, 2007, 11:09:59 am »
Thanks for replying!
ARGH I see... Thanks for posting the picture with circled switches, etc... It makes sense... I had a feeling when I did the CAD drawings.I just ordered from Divemaster: 2 Mag Stick PLUS + red ball top sticks ("regular" length) - that's all I know about what I am getting :)
I'll mount them from under then... What people usually do I think - from looking at people's CPs here.
(I didn't understand "Andy sell shorter balltop for metal panel. Battop (III groove 70mm) for metal  panel you will buy only in iL " ... Illinois?)
kowal
  • Suzo 4ever
« Reply #3 on: July 22, 2007, 04:30:24 pm »
Andy Warne http://www.ultimarc.com/JShopServer/section.php?xSec=6
 "regular length" is short baltop - my fault. it will be OK in metal panel
iL - http://www.industrias-lorenzo.com/
ARTIFACT
« Reply #4 on: July 23, 2007, 08:56:03 am »
I need to order something ... from Spain?
If I mount them from under ... regular length is too short to do that?
I messaged Divemaster to switch with longer length balltop sticks ... if my order wasn't shipped yet (I have a feeling he already shipped my stuff).
I am really confused now!
« Last Edit: July 23, 2007, 09:10:55 am by ARTIFACT »
ARTIFACT
« Reply #5 on: July 23, 2007, 09:35:21 am »
my CP is 3/4" (~19mm)
Isn't there enough space between the mountplate and the connectors? (attaching a picture)
Especially if I use the router to cut an inset at the top to flush the mountplate?
I guess I just need ot wait for the control parts to arrive, and assess ... IF Divemaster replies and has time to switch my balltops to the longer length model then I can mount under and it'll be ok I think. My bad for not planning this with more attention.
We'll see!
thanks
BobA
  • What Me Worry?
« Reply #6 on: July 23, 2007, 09:39:45 am »
You could top mount the plate by routing the area underneath to clear your connectors .   You would be routing on top for the plate and underneath to clear the connectors.
ARTIFACT
« Reply #7 on: July 23, 2007, 10:28:35 am »
Perfect!
I'll do that then.
Thank you very much.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: July 23, 2007, 11:08:56 am »
There is no need to do anything special, just remove the faceplate from the joystick (4 screws) , cut the correct size hole in the panel, recess the faceplate into the top and mount it, then screw back the body of the stick onto the faceplate.
Andy
ARTIFACT
« Reply #9 on: July 23, 2007, 02:00:24 pm »
OK then! perfect... thank you very much.
I love the BYOAC community.
Jimbo
  • Last login:May 04, 2024, 01:20:14 pm
    • Wood Finishes Direct
« Reply #10 on: July 26, 2007, 04:45:47 am »
I recently bought 2 of the Mag Stick Plus joysticks from Ultimarc, and I plan on mounting them this way too.  Seems easy enough but I think I'll need to remove the joystick shaft if I want to put the dust washer on top of the CP... just have to remember how to assemble it again!
Jimbo
dternes
  • Last login:May 07, 2009, 11:29:04 pm
« Reply #11 on: January 25, 2009, 11:43:49 am »
I am in the process of cuttnig out my control panel and am using the magstick plus stick.
I had planned on top mounting and have actually already cutout an area large enough for the middle section of the stick to fit iun from the bottom.  I had planned to use the top mounting plate to sandwich the 3/4" mdf cp.
My concern looking at it now is that even though the mounting plate for the stick will set flush wth the top, the screws, holes, and plate edges will be visible indentions through my cp graphics.  Any ideas?
