Main > Project Announcements
Operation 'Lowboy' 95% Done! Updated 5th October '07
<< < (11/17) > >>
ARTIFACT:
Very cool!!
I love this cab design!
theCoder:
With the vinyl only on one side of the t-molding, is that going to cause a problem?  Does the t-molding seat OK on the non-vinyl side?
Great craftsmanship.  Very clean.
RXII:
--- Quote from: theCoder on September 09, 2007, 03:27:09 am ---With the vinyl only on one side of the t-molding, is that going to cause a problem?  Does the t-molding seat OK on the non-vinyl side?
The vinyl is going on both sides, the outer panels will be the very last thing I cover as I want to make sure everything else lines up and fits before I cover it. Once the vinyl goes on I will not be able to remove the top marquee shelfs etc as the screws will be filled and covered. The t-mould sits perfect as the staples and tapped down to sit below the level of the vinyl, I am really happy with that side of the build.
Thanks,
Simon.
Dire Radiant:
I love the clean look of this. Your control panel layout is the work of a true genius (This may or may not have something to do with the fact that it's identical to mine) The nice thing is that these are so compact that you can easily build another for vertical games and have the best of both worlds.
RXII:
Hi guys,
             Bit more of an update.....I have redone the speaker panel and I am glad I did. I lashed out and bought some 'proper' acoustic speaker cloth from a local electronics store. I have left the vinyl on there but removed the existing cloth off the speakers. I simply wrapped the cloth over the whole panel and it is now as I originally pictured it..you can just see the speakers through the cloth and they even sound better than the other black material I had over them.......
I have also stopped up all the screw holes in the side ready to cover the side panels.
There is light at the end of the tunnel!
Simon.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
