Author Topic: Atari "Volcano" Button Help  (Read 1820 times)
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« on: July 13, 2007, 05:58:01 pm »
These buttons have multiple connections...for the button functionality as well as the light.  Does anyone know what connections are for what (ground, power for the light, etc).
grantspain
  • Last login:Today at 03:44:33 am
Re: Atari "Volcano" Button Help
« Reply #1 on: July 13, 2007, 06:03:23 pm »
get your meter out and check the continuity,when you press the button the dead short will be the switch and the lamp will not change and will have some resistance
SirPeale
  • Green Mountain Man
« Reply #2 on: July 13, 2007, 06:28:05 pm »
Not only that, but get it in your hand and physically look at it.  Everything is pretty self-explanatory.   You can see that the switch is separate from the light.  Standard microswitch rules apply here.  The light IIRC has + and - labeled, so you know how to hook up your LED.
« Reply #3 on: July 13, 2007, 06:46:21 pm »
I have one in my hand as I post this.   The left set of three have the NC and NO tabs labeled and the right set of two has the ground tab labeled.  It also says they consume 0.1A at -125VAC.
-125VAC?  Odd.
SirPeale
« Reply #4 on: July 13, 2007, 06:58:02 pm »
That's what the switch can handle.  125V @ .1A
FrizzleFried
    • Idaho Garagecade
« Reply #5 on: July 13, 2007, 07:02:33 pm »
Mine has 4 posts on one side and 2 on the other.  The 2 by themselves appear to be the lighting side whereas the other 4 posts are labeled NC and NO (I am having a brain fart,  can someone tell me what NC and NO mean...durrr?!).
grantspain
« Reply #6 on: July 13, 2007, 07:09:56 pm »
NC=normally closed
NO=normally open
com=common
 :dizzy:
FrizzleFried
    • Idaho Garagecade
« Reply #7 on: July 13, 2007, 07:11:00 pm »
NC=normally closed
NO=normally open
com=common
 :dizzy:
I had the OPEN and CLOSED part but couldn't put my finger on the "N" word.
grantspain
« Reply #8 on: July 13, 2007, 07:13:51 pm »
and i am normally drunk :cheers:
Kevin Mullins
    • Me on Myspace
« Reply #9 on: July 13, 2007, 07:23:30 pm »
Obviously .....   :cheers:
grantspain
« Reply #10 on: July 13, 2007, 07:27:05 pm »
she's a looker ain't she :cheers: :cheers:
Jouster
  • Flap, Flap...Crash
« Reply #11 on: July 13, 2007, 07:31:48 pm »
Ouch...be carefull...you need to watch yourself when talking about the N word.
Jouster
torez
  • Last login:December 20, 2009, 09:40:12 pm
« Reply #12 on: July 13, 2007, 08:04:12 pm »
I have 6-lead volcano button with 250 VAC (originally it was in Bally/Midway cab), same as FrizzleFried's.  I use two NO (normally open) for  button/credit press.  From my inspection, I see no solder residue on the two in the center (out of 4 in a row).  Other two sideways would be the led light.  They are right in the center, so they look like led leads anyway.
The two center leads (out of 4) would be for circuit always closed and you open it when you press the button.
Ps.  You have to use resistors to reduce current to these leds.  Search this site here for other posts like this.
« Last Edit: July 13, 2007, 08:09:38 pm by torez »
Official Omega Race WR Holder:
1 credit:  3,847,350
2 credit:  4,823,750
« Reply #13 on: July 13, 2007, 08:08:53 pm »
We were going on the fact that he said Atari.
torez
« Reply #14 on: July 13, 2007, 08:11:59 pm »
-125VAC?  Odd.
These are maximum allowable values.  You have to calculate proper resistance, so the current to the led is <=0.1A.
1 credit:  3,847,350
2 credit:  4,823,750
SirPeale
« Reply #15 on: July 13, 2007, 08:33:51 pm »
-125VAC?  Odd.
Amps are draw, not output.
Jouster
« Reply #16 on: July 13, 2007, 09:11:08 pm »
Can you still buy these somewhere?  I thought  they were no longer available.
Or are there cheap (or not so cheap) knock offs available?
Jouster
Kevin Mullins
    • Me on Myspace
« Reply #17 on: July 13, 2007, 09:35:52 pm »
Here's one source......
http://www.ram-controls.com/order-cones.html
There was an "Atari Cone Button War" going on awhile back about reproduction of these amongst some people. Not sure who all else is still supplying these though.
BrentRadio
  • Last login:March 11, 2021, 06:26:04 am
  • Stop by for a game and a beer!
    • Jack Daniel's Barcade!
« Reply #18 on: July 13, 2007, 11:29:35 pm »
Jouster, did you need the buttons or the cones that go on them?
I have the cones very cheap if you need some.
Brent
Jouster
« Reply #19 on: July 14, 2007, 05:34:20 pm »
I was really more curious than anything...I thought that I had read somewhere that the Atari cone buttons weren't being manufactured anymore.  $20 a button is a bit much...but then again...I don't have a cab to put them in yet.  I'm sure when I start my next project that won't seem so high.
Jouster
SirPeale
« Reply #20 on: July 15, 2007, 07:53:54 am »
The switch assembly isn't being made any more.  People have made repro cones, however.
Level42
« Reply #21 on: July 15, 2007, 10:18:18 am »
Luigi from Germany sells repro cones, and both used and new switches for very good prices, although the Euro-Dollar rate may bring things up for the US folks here...
http://forum.arcadecontrols.com/index.php?action=profile;u=6387
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #22 on: July 19, 2007, 09:28:24 pm »
-125VAC?  Odd.
I don't believe this to be correct -
The LED draw is not specified, this 0.1A is the switch contact rating.  Allowing 100mA (at 100% duty cycle) to the LED most likely will damage it.  While I don't know just what the rating on the LED is, most 'normal' ones are rated for a max of 20mA (0.02A).  Usually only the 'superbright' ones are rated at more than 20mA.  I have my doubts that superbrights were even invented 25-30 years ago let alone used in these buttons...
I suggest calculating resistance so that the current to the LED is limited to 10-20mA.
If I do not respond to your post in a timely manner, feel free to PM me.
BrentRadio
« Reply #23 on: July 19, 2007, 11:56:50 pm »
Todd at TNT Amusements has the buttons for $10 each.
Brent
