Main > Main Forum
Help sourcing sheet metal(?)
NAH:
I've cut aluminum diamond plate with a jigsaw and metal blade. Worked very well adn was very quick. You just have to go slow when you go over the bumps because the metal is so much thicker there. Its best to clamp the metal down to reduce vibrations and walking. It was very easy to cut. I've had some plasma cuts done by a machine shop that weren't very clean, but the jigsaw saw makes a very clean cut. The blade probably wont last too long, just go slow.
wee beastie:
NAH, are you serious?!!?
You cut it with a jigsaw. I never really thought to try it. Anyway, about how thick was the stuff you cut?
OSCAR:
Not to confuse the issue, but there are different kinds of diamond plate and you might want to make sure you get what you want. The stuff shown in the original post is commonly known as Inland 4-way plate, checkered plate, or just floor plates. This is what my company uses all the time for decking & platforms in automotive plants. The pattern has smooth surfaces and you can easily run your hand across it, no snags.
The bright finish aluminum diamond plate used on toolboxes & running boards typically has somewhat sharp edges and can easily snag on clothing or even cut you if you are careless. Here's a pic of the sharp stuff: http://www.billingssheetmetal.com/toolboxb.JPG.
BillyJack:
Thanks guys, I talked to my dad, he says he's cut the stuff with a reciprocating saw before, and he has other blades that can do the job and leave a good cut... Damn it feels good to be a gangsta, well at least to have family that has all the stuff for any job.
Thanks for the help naming and sourcing,
Billy Jack
ps i'm tired of being a newbie... i'm more of a lurker... i've gained much knowledge but posted very little.
