Author Topic: Question on Pac-Man paint color.  (Read 913 times)
HighNoon
  • Last login:December 08, 2023, 08:21:37 am
« on: July 08, 2007, 11:49:36 pm »
Hello,
Can anyone let me know what "finish sheen" the black should be around the monitor of a Pac-Man?
I'm referring to the wood side area and up by the speaker grille.
Should it be flat black, or a satin?  What was the factory sheen?
Thanks in advance!
« Last Edit: July 09, 2007, 11:09:21 am by HighNoon »
rescue161
  • Last login:January 29, 2022, 04:11:18 pm
  • I built my own Cabaret machine!
Re: Question on Pac-Man paint color.
« Reply #1 on: July 09, 2007, 12:23:31 pm »
Mine appears to be a satin finish.  It's factory and has never been refurbished.  It's definitely not flat black.
"Censorship reflects a society's lack of confidence in itself." - Supreme Court Justice Potter Stewart
spystyle
« Reply #2 on: July 09, 2007, 01:19:07 pm »
Here is a big list of the commercial equivalent of cab colors:
http://www.oleszakcreative.com/paint.asp
« Last Edit: July 09, 2007, 03:21:44 pm by spystyle »
rescue161
« Reply #3 on: July 09, 2007, 01:35:10 pm »
He's wanting to know about the black paint used around the speaker and the monitor, not the yellow outer paint.
amadama
  • Last login:September 29, 2019, 04:44:52 pm
« Reply #4 on: July 09, 2007, 02:38:36 pm »
Satin finish.
The real deal machines used oil based enamel. It's easier to use a latex paint if you are going to use a roller to apply.
I have used Rustoleum Satin Black Oil based and Krylon Satin Black Latex (water based).
Make sure you use a good foam roller designed for "smooth" or "super smooth" application. A smaller size roller is best.
Good luck,
Alex
HighNoon
« Reply #5 on: July 09, 2007, 04:16:29 pm »
Thanks guys!
It's been a long time coming, but I do believe the end is near.  (with the Pac restoration)
Why do I keep starting projects that I know are gonna take me forever?
Thanks again - hope to update you soon.
spystyle
« Reply #6 on: July 09, 2007, 04:55:11 pm »
...Why do I keep starting projects that I know are gonna take me forever?...
Because it keeps you out of trouble?
Busy people are well behaved people :)
