Main > Main Forum
Dual Topgun problems...
u_rebelscum:
Sorry coming in late, but you should be able to use latest smog driver, current mame, and
mouse 0
joystick 0
lightgun 0
dual_lightgun 0
lightgun_device lightgun
FWIW, lightgun_device lightgun means "if the game has a lightgun type input, then act like lightgun 1, else leave lightgun to what it says in ini file."
Next you should make sure the guns are mapped correctly (detailed howto).
If it still doesn't work, you have to make sure EMS driver is totally uninstalled, as it conflicts with smog's driver, IIRC. I think you have to go to device manager (start, control panel, system, hardware, device manager is one way), turn on viewing hidden devices, and find & uninstalling the EMS driver.
Kaytrim:
Ok got a little time tonight to work on it. I have it working in Windows and now it is working in MAME but it is jerky and hard to hit the targets.
Any ideas?
TTFN
Green Giant:
I am pretty sure there is a sensitivity control in Smogs control center. Adjust this to change the jerkiness/speed, more jerky means it moves faster and vice versa.
Also, how big is your tv, where are you standing, and where are the led strips mounted?
Kaytrim:
--- Quote from: Green Giant on July 12, 2007, 09:40:43 pm ---I am pretty sure there is a sensitivity control in Smogs control center. Adjust this to change the jerkiness/speed, more jerky means it moves faster and vice versa.
Thanks, I'll look into that tonight I hope. I am using a 19" CRT computer monitor with the bars mounted above and below. I am standing about 5' back and could stand closer.
TTFN
Green Giant:
It will probably never be perfect because you are using a 19" monitor. Most shooting games in the arcades have rather large screens.
