Main > Main Forum
Happs pushbutton color shade
Pages: << < (5/6) > >>
_Iz-:
BASSOFeeSH: what is the red ball top joystick in the center of your panel? (who make it, where did it come from?)
BASSOFeeSH:
--- Quote from: _Iz- on April 24, 2003, 02:15:35 pm ---BASSOFeeSH: what is the red ball top joystick in the center of your panel? (who make it, where did it come from?)
Ultimarc Controls
J-Stik (Japanese) Ball-Top
--- Quote ---These two Japanese sticks are the type used in most Japanese cabinets such as the Sega Naomi and other modern cabs. They have a light spring pressure for really fast movements.
The travel on these is longer (same as Happ super) and has two selectable settings, available by turning over the restrictor plate, which has a chamfered hole. Another nice feature is the long switch actuators which allow exact "tuning" of the switch sensitivity with careful use of long-nosed pliers. Operates in 8-way or true 4-way mode by rotating the restrictor.
Available in red only.
_Iz-:
Sweeeet!  I've been really thinking about getting that exact one. Need to wait till I can afford the optipac and get both together. How do you like it?
skirge66:
silvervice's pic i think has the best representation of actual colors...the green buttons in his pic match mine perfectly
BASSOFeeSH:
--- Quote from: _Iz- on April 24, 2003, 02:52:58 pm ---Sweeeet!  I've been really thinking about getting that exact one. Need to wait till I can afford the optipac and get both together. How do you like it?
The throw's longer than the 4-ways you'll see at the arcades, but this stick is more versitile & easier to mount.
Go to full version
