Main > Main Forum
virtua tennis ppjoy problem
rockmes:
--- Quote from: Allochtoon on July 04, 2007, 12:32:48 pm ---I've got a problem running virtua tennis multiplayer.
I added 3 virtual joysticks, all three with 2 axes and 8 buttons. They all work in the input configuration program of Virtua Tennis, and when testing them in windows. When i try to multiplayer in the game only the first player (none of the virtual sticks) is recognized. What gives?
If you do a search in this forum you will find the proper setup for this, cos l had the same issue a very long time ago. lm positive that the axis needs to be 4 , buttons dont matter. make sure you config it properly in Vtennis and save before you exit .
rockmes:
--- Quote from: Zebidee on July 06, 2007, 01:23:14 pm ---I guess that you have also run the VT config program (VTCONFIG.EXE) to set controls?
You should run this with all PPkey virtual joysticks running. Otherwise the game won't recognise your extra players.
yep l can confirm this as well . they need to be running in the background before you can use the setup for your joys for the game
Allochtoon:
thanks for all the help guys, it seems the problem lay entirely with the specific version of virtua tennis i was using, now its working fine!
ChicagoDave:
What versions of Virtual Tennis were you using? Which one worked? Which one didn't? This will be good to know for future reference... Thanks.
Moose13:
I'm haveing problems with PPjoy.
I download it, installed it, but don't know much where to go from there.
I try to install a virtuall device, but I can't configure it. I hit the "scan button" and try to press a button (for buttons) and move the stick for axis, but nothing but "invalid" beeps.
I've searched and found a seperate program to make an ini file with teh buttons, etc. That worked and I put the ini file in the ppjoy folder.
Now what? do you have to keep ppjoy running (i.e. in the startup folder) in teh background? Maybe a batch file to run ppjoy and the ini file together?
Is there somethign else I need running in the background?
I've looked through the net and on this site, and still can't figure it out. ???
