Front End Support > MaLa Frontend
GameLists: Multiple emuls in same list work-around solution
<< < (63/68) > >>
mitsurugi:
With windows console (cmd) i have enter in: D:\ROMS\Dummies roms\vs2_2k and then put.-
cd ..\VirtuaStriker2emulator
closemul.exe "D:\ROMS\Dummies roms\vs2_2k\vs2_2k.zip"
and makaron works fine.
But when I try it in mala, nothing happens. I'm sure the error is in the first line, mala don't enter in ::vs2_2k
mame.cmd.-
if "%2%" == "vs2_2k" goto vs2_2k
groovymame.exe %1 %3
exit
:vs2_2k
exit
Javy3:
nice
cavepainter:
I'm trying to get in on this now myself and running into a problem.
I can't seem to be able to get mala to pass %2 to mame.cmd. Is anybody willing to throw some ideas in my general direction?
Here's my mala log of my attempt to run Dragon's Lair via the dle21 rom, which is location in my Daphne\roms folder:
2013/06/06  13:50:01.07   Info: CtrlStartGame: MAME: FMameCommandline (config) = %rom% %path%
2013/06/06  13:50:01.08   Debug **: CtrlStartGame: MAME Command Line replaced %path% = %rom%
2013/06/06  13:50:01.08   Debug **: CtrlStartGame: MAME Command Line replaced %rom% = dle21
2013/06/06  13:50:01.09   Debug **: CtrlStartGame: MAME Command Line replaced %parent% = dle21
2013/06/06  13:50:01.09   Debug **: CtrlStartGame: MAME Command Line replaced %ext% = dle21
2013/06/06  13:50:01.09   Info: CtrlStartGame: MAME: Converted Commandline = mame.cmd dle21
2013/06/06  13:50:01.09   Info: Saving game list: D:\Games\mala\1983.mlg
2013/06/06  13:50:01.10   Debug **: Sound Trigger (if set) SOUND_STARTGAME(or Muzac) ---------------------------------------------------
2013/06/06  13:50:01.10   Info: Starte: Dir = D:\Games\mame\
2013/06/06  13:50:01.11   Info: Starte: Command Line = mame.cmd dle21
2013/06/06  13:50:01.11   Info: Starte: Current Memory used: 42,440 K
2013/06/06  13:50:01.11   Info: Starte: Cancel any Display & Video Delay due to game start
2013/06/06  13:50:01.11   Debug **: Starte: Video windows Disabled as Game is about to be launched
2013/06/06  13:50:01.12   Info: Starte: Set dir: D:\Games\mame\
2013/06/06  13:50:01.12   Info: Starte: Starting: dle21
2013/06/06  13:50:01.12   Info: Starte: Create process: mame.cmd dle21
2013/06/06  13:50:01.18   Info: Starte: Ending Game:  >>>>>>>>>>>>>>>>> Quit:
cavepainter:
Re: my own issue of mala not passing along the path....
I've made a little bit of progress. In the mala gamelist editor I added the path to the rom listing. I thought mala was supposed to find this automatically somehow, but apparently it isn't doing it. As it is now, I'll have to add the paths by hand for every game that I want to run with an emulator other than mame.
Clearly you guys aren't doing this. Any idea why mala would not be finding the rom path automatically? I have 3 rom paths set up in the options and search subfolders enabled.   :dunno
BadMouth:
--- Quote from: cavepainter on June 06, 2013, 03:45:26 pm ---Re: my own issue of mala not passing along the path....
I had the same problem.  It's buried somewhere in this thread, but even digging back through the thread knowing it's there, I can't find it.
One of the options needs to be unchecked in the advance features where you set the rom path.  I think maybe it was "only working games" even though I had changed them to working in the xml and they show up in the list.  Try that, refresh, then check the paths again.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
