Main > Main Forum
illuminated pushbutton help
fjl:
--- Quote from: infamous360 on July 03, 2007, 01:36:36 pm ---its an older one Compaq p2 40gb hdd, 384 ram. it has an agp slot... I need a card that outputs to TV i dont want to spend alot hopefully less than $80 but if i HAVE too i will spend more... I am upgrading the ram a little bit more (up to 512) and adding 2.0 usb slots
I suppose it can be good enough to run MAME on. But personally I wouldn't run MAME on it for the higher end games like Marvel Vs Capcom. I'm going to run MAME on my old PC a P4 3.0Ghz with 1GB of memory and a All-In-Wonder 9800 SE video card with 128MB of ram.
infamous360:
I am not running mame... I am running stepmania (its like a ddr mame) whats a good graphics card? the pc has AGP
Dreamwriter:
--- Quote from: infamous360 ---lik
ok i watch this http://www.retroblast.com/articles/coindoor.html what kind of wire do i need? could you send me links?
I don't understand your question: there aren't different kinds of wire. There are different thicknesses, but the thickness to use is pretty obvious when you see the molex connector, anything smaller than that will work.
infamous360:
links to the connectors?
infamous360:
you talkin about this ???
http://www.radioshack.com/product/index.jsp?productId=2104091&cp=2032058.2032231.2032283&parentPage=family???
oh will this graphics card work? http://www.geeks.com/details.asp?invtid=V9600XT-256A&cat=VCD
