Main > Main Forum
Is there anywhere to buy monitor bezels besides Happ?
Pages: << < (2/3) > >>
Vesper:
Give Happ a call.  When I ordered my bezel, it was backordered from their Chicago warehouse.  I called them and the customer service rep said they could ship one instead from their Las Vegas warehouse.  Got it a few days later.  It would seem that they allocate the closest warehouse to supply your parts, and backorder status is based on that.
anthony691:
Well... what kind of monitor is it? Both of the one's I tried (a Sun and a Viewsonic 23") Had smaller inner metal cases, so I just removed the outer case. I can't recommend this for all monitors, however it works great on some.
JLR2000:
Just a note about painting the Monitor....
I planned on spray painting the monitor on two of my projects. On a whim (and since it was still below freezing outside) I decided to try permanent marker.  I had one of those BIG markers for sign making.  It worked great, it was easy to clean up the little overage I got on the glass, and it didn't require taping everything off.  Turned out to be a perfect solution for me, and was much easier and cleaner to do.....
Good Luck.
paigeoliver:
That bezel isn't going to match up to your PC monitor anyway, at least not with it in the case. Your going to have to take the front of the case off if you want that bezel to be of any use at all.
Cue-Ball:
Why wouldn't the bezel work without removing the case?  If the 19" bezel is anything like the 25" bezel (one of the 25s came in my cabinet) then it should work.  The bezel is much deeper than the front plastic on the monitor so i would think it should easily cover up the monitor's case.
Go to full version
