Main > Main Forum
paint color.
Pages: << < (2/2)
fjl:
--- Quote from: Zeno on July 01, 2007, 06:50:23 pm ---Paint code link...
You can thank prOK for this one.
http://www.rgvac.com/paints.asp
As payment, can you post a photo of the cab you are converting?  Just curious.
Wow, thanks a lot dude! I really needed a link like this.  :notworthy:
As for Donkey Kong colors, how's this...
http://appolo.com/colorcodes/donkey_kong_blue.htm
http://appolo.com/colorcodes/donkey_kong_orange.htm
This is the one I'm using for mine  ;D
http://appolo.com/colorcodes/qbert.htm
ptpeter:
The DK blue would work for a Vs. Mario but it just looks a little to blue, Not light enough.
What the best way for getting a smooth finish? Roller or Brush?
fjl:
Best smooth finish would be to use a spray gun with an air compressor. I was thinking of going that way myself but buying an air compressor(and has to be a good one at that) is out of the question at the moment.
Definitely a roller leaves a smoother finish than a paint brush. Many people here swear on a foam roller for a nice smooth finish. Haven't tried one myself but I'll probably test it out.
JimmyU:
I'm not sure about the paint, but I want that marquee. ;D
Jeff AMN:
You can get a near perfect finish with a roller. It's much smoother than you'll get with a brush. Just as a tip, any type of painting you do will look smoother if you lay the cab on its side. Gravity helps you out and smooths your strokes together.
Pages: << < (2/2)
Go to full version
