Author Topic: CPS3 Emulator - any wrapper?  (Read 6293 times)
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« on: July 01, 2007, 11:21:15 am »
The CPS3 emulator runs fine and dandy on my cab, with the likes of streetfighter 3 running at full speed. Now that CPS3 emulation is almost complete it is time to think about implementing this on my cab more formally via MAMEWAH. Anyone know of any decent wrapper solution or command line launch for the CPS3 emulator?
http://nebula.emulatronia.com/
gonzo90017
Re: CPS3 Emulator - any wrapper?
« Reply #1 on: July 01, 2007, 12:52:45 pm »
I'm sure Howard's keypress simulator would work http://dragonking.arcadecontrols.com/static.php?page=wrapperdownload
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #2 on: July 01, 2007, 01:33:14 pm »
Have you tried MAME yet? Or are you trying to get a speed bump out of a dedicated emulator?
I'm only vaguely following it all since I don't care about the games themselves, but my understanding is that if you can run CPS2 at full speed in MAME CPS3 is pretty close.
darthbane2k
« Reply #3 on: July 02, 2007, 07:14:26 am »
It actually already runs from the command line!
Eg  "emulator.exe sfiii" will launch Streetfighter 3!
I now have the CPS3 games on my cab via mamewah!
Point to note, the emulator wont work if you do not have your cab PC in 32 color depth.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #4 on: July 02, 2007, 09:34:27 am »
mame .116u2 does the cps3 games :)
jeffo
  • Last login:May 01, 2010, 09:12:59 am
« Reply #5 on: July 02, 2007, 02:26:51 pm »
wait
so...
3rd strike now works 100% in mame??
Banana Republik.
AcidArmitage
  • Last login:February 21, 2015, 02:19:05 am
  • keeeyaaaii
« Reply #6 on: July 02, 2007, 02:58:13 pm »
isnt it .116u3?
RecklessAbandon
  • Last login:October 03, 2009, 04:29:46 pm
    • the rusty joystick
« Reply #7 on: July 02, 2007, 03:17:49 pm »
pretty much 100% in 116u3, just has a few graphical glitches
runs sf3 and jojo 100% and warzard around 80% on my 2000+amd
lanman31337
« Reply #8 on: July 02, 2007, 04:12:19 pm »
u2 was the big update to include the cps3 i do believe - i'm running u3 and all the games run 100 percent on my box.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #9 on: July 02, 2007, 04:20:41 pm »
This may sound like a stupid question, but is it possible to patch an older version with the CPS3 compatability in 116u3?
I'm currently using a hi-def patched 108.
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #10 on: September 09, 2007, 04:45:47 am »
How exactly would I go about doing this?
Im running MAMEwah ver 1.62b13 and I dont know how to intergrate the dos prompt you have above.
superart
  • Permanent ban
  • Last login:April 29, 2008, 07:16:11 pm
  • Permanent ban
« Reply #11 on: September 09, 2007, 01:18:58 pm »
hey why don't u get mame++.118u4 it will for sure run the cps3 games at one hundred percent. Also with this u can play all ur games online with others, and i mean all of ur games, espicailly street fighter 3s. One thing to note, this emulator dosent have to have the roms in its roms directory. You just have to piont it to the rom directory(options-directories). This means that u can have your roms in u regular mame directory, then when u play online just do it via mame++. U can also play ur regular mame online va kaillera client, but i haven't seen anyone play with the regular mame.
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« Reply #12 on: September 09, 2007, 07:26:26 pm »
Ummmmmm....... I don't know what I'm doing wrong, but I have the latest Mame and Mala and my SFiii3. doesn't work.
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #13 on: September 10, 2007, 02:26:13 am »
Check your files, you must have a rom and a chd.
fjl
  • Pixels Rule!
« Reply #14 on: September 10, 2007, 02:28:45 am »
CHd is important
Kajoq
  • Last login:May 07, 2024, 11:32:33 pm
« Reply #15 on: September 10, 2007, 09:14:21 am »
There is actually a version of 3s that is a Japanese NO-CD version that doesn't require a .chd
postalp123
« Reply #16 on: September 10, 2007, 09:57:51 am »
Because:
A) Im running CHD'less (Which MAME doesnt do)
and
B) Im on a lean PC and need all the juice I can get out of the Nebula based emu, on MAME the games would chug.
