Author Topic: Does anyone have MAME displayed vertically on a 5:4 monitor?  (Read 2065 times)
  • Last login:Yesterday at 07:54:28 pm
I just can't seem to get a fullscreen picture.  I get letterboxing on all 4 sides.  I'm using MAME .87 and MaLa as my front end.  I need to work this out!
Thanks!   :cheers:
ahofle
    • Arcade Ambience Project
Re: Does anyone have MAME displayed vertically on a 5:4 monitor?
« Reply #1 on: June 30, 2007, 05:57:45 pm »
Have you tried the 'aspect' setting?  I'm not sure if it's in your older version of MAME, but in recent versions you can tell MAME what aspect ratio monitor you have.
« Reply #2 on: June 30, 2007, 06:00:12 pm »
I tried changing the aspect from 4:3 to 5:4 in the mame.ini file and it had no effect.  I also tried changing the resolution from "auto" to 1280x1024 and the picture got worse (squished like crazy).
Kaytrim
  • I'm too nice a guy
« Reply #3 on: June 30, 2007, 06:05:04 pm »
You need to reverse the numbers because you have the monitor vertical instead of horizontal.  The short side as now at the top instead of the long side.  That is why your image squished when you set the resolution.
Kaytrim
« Reply #4 on: June 30, 2007, 06:17:28 pm »
Kaytrim
Thanks Kaytrim - I already thought of that and tried a 4:5 setting as well as a 1024x1280 setting.  No dice.  Any other ideas?   :cheers:
« Reply #5 on: June 30, 2007, 06:38:19 pm »
This is my MAME ini file:  I've messed around with resolution and screen_aspect and no luck.
### mame.ini ###
### Frontend Related ###
clones                  1
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
cleanstretch            auto
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           5:4
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
high_priority           0
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   0
joystick                1
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
### Mame CORE video options ###
norotate                0
ror                     1
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
crconly                 0
bios                    default
# state                 <NULL> (not set)
### Configuration options ###
readconfig              1
verbose                 0
« Reply #6 on: June 30, 2007, 06:52:19 pm »
Javeryh...
Are you still trying to get the onboard intel card to work? If so.... seriously, just nix it. Every machine I've tried to use with an onboard intel card will not display properly. You could PM UncleT, I think he had some luck with his onboard intel card.
If your not using an onboard intel card.... I don't know what to say.  ;D
« Reply #7 on: June 30, 2007, 07:04:52 pm »
Oh yeah... I forgot about that.  I kind of gave up on the setup a few months back thinking that I'll worry about it when the cab is done... well the cab is done.  I'd really like to get this thing working somehow andI'm not afraid to spend a little money to do so.   ;D
Can I upgrade my computer with a video card that would work?  It's kind of an old computer (new in 2000).  I'm stuck with this monitor as I built the entire cab around it - I'd be willing to upgrade though is someone could point me in the right direction.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: July 02, 2007, 02:10:18 am »
I've been able to do it, with an intel onbound.  Haven't used 0.87 in a long time, though.
With the screen rotated vertical and the desktop rotated to match, I had
Code: [Select]
switchres               0
keepaspect              1
screen_aspect           4:5
and the ror, rol, and other rotate options at default.  When I had the screen_aspect the 5:4 way, it was very wrong.  You get small black bars on the sides.
If you're talking about vertical games on a normal 5:4 screen, same as above except just switch the screen_aspect to 5:4.
Robin
Knowledge is Power
« Reply #9 on: July 02, 2007, 10:05:55 am »
Code: [Select]
switchres               0
keepaspect              1
screen_aspect           4:5
Cool - I can't wait to try this when I get home... one question - how do you rotate the desktop?  I'm assuming you have Windows and everything on your computer running vertically (at 4:5).  This would mean that I should set "ror" and "rol" to "0" because MAME will be vertical by default, right?  This would be great if it works.  Thanks!   :cheers:
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #10 on: July 02, 2007, 12:03:27 pm »
Use iRotate, if your card supports it, to have Windows running vertically. It's what I use on my cab.
Kaytrim
« Reply #11 on: July 02, 2007, 12:20:14 pm »
iRotate doesn't work with the Intel onboard video chips.
« Reply #12 on: July 02, 2007, 12:30:12 pm »
:angry:
Looks like a new video card and some more RAM is the only way to get this thing to do what I want it to do...
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: July 02, 2007, 12:51:47 pm »
According to the support forums, iRotate works with "-Intel Extreme Graphics and newer",
can't hurt to try it anyway.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #14 on: July 02, 2007, 01:50:34 pm »
On my work computer with Intel 82915G Express onboard chip, I can rotate with the driver.  One way to get where I need to go is: control panel, display, settings, advanced, intel graphics media accelerator driver, graphics properties, display setting, enable rotate.     Aren't GUIs the best?  ::) ;)
And yes, ror etc are set to 0.
Robin
Knowledge is Power
« Reply #15 on: July 02, 2007, 11:48:39 pm »
Just tried this - no luck.  I don't have that feature I guess... :'(
Kaytrim
« Reply #16 on: July 03, 2007, 10:18:24 am »
With the older chipset that you have I am not surprised that you don't' have the rotate feature.  I couldn't do it on Dad's Bartop even with updated drivers from Intel.
« Reply #17 on: July 03, 2007, 10:55:03 am »
yeah, that was my last ditch effort - looks like I'm in the market for a new computer.  Do you think I should order parts for my existing one or just try and get a $300 compaq or maybe order a new motherboard, video card and some RAM and cobble one together using my old case, DVD-ROM and hard drive??
Kaytrim
« Reply #18 on: July 03, 2007, 11:59:54 am »
This is still good for what you want.  Just add ram and a video card and you will still be cheaper than buying a new computer.  Or you could just add some ram and it will be good for a horizontal profile MAME machine.  Another option is to check out creigslist for a newer computer in your area.
TTFN
