Author Topic: Happ trackball pin out? My bad, Imperial, is the one that I need.  (Read 7944 times)
Hawk Daddy
  • Last login:April 18, 2020, 10:01:27 pm
  • Only True Pimps Have Arcade Machines!!!
So what is the standard trackball pinout for a happ trackball?  LIke the y-dir, y-clk, x-dir, and x-clk, and the grounds?
Hawk
« Last Edit: June 29, 2007, 02:45:02 pm by Hawk Daddy »
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
Stobe
  • Trade Count: (+17)
  • Last login:January 23, 2024, 05:08:05 pm
Re: Happ trackball pin out?
« Reply #1 on: June 29, 2007, 07:49:53 am »
Not a pinout, but a "wire-out" at least:
 Left/Right                                                   Up/Down
1) Output - A  (Blue Wire)                         1) Output - A  (Green Wire)
2) +5V           (Red Wire)                            2) +5V            (Red Wire)
3) GND         (Black Wire)                          3) GND          (Black Wire)
4) Output - B (Yellow Wire)                        4) Output - B (Orange Wire)
The six pins should corelate to the 4 signals plus +5V and Ground (being split to the 2 optic boards)
And here's the pin numbers:
PIN WIRE #1 – Black 1 Yellow + 12 Volts DC
PIN WIRE #1 - Red PIN WIRE #2 – Red 2 Black Ground
PIN WIRE #2 - Yellow PIN WIRE #3 – Yellow 3 Red + 5 Volts DC
PIN WIRE #3 - Green PIN WIRE #4 – Green 4 Black Ground
PIN WIRE #5 - Blue PIN WIRE #5 – Blue
PIN WIRE #4 - Purple PIN WIRE #6 – Purple
Hope that makes sense.
-Stobe
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: June 29, 2007, 12:57:43 pm »
LIke the y-dir, y-clk, x-dir, and x-clk...
FWI, the TB outputs a quadrature signal, not a direction & amount like in the question.  IOW, "Output A" in Stobe's answer is one of the two sensors for that axis and Output B is the other sensor, and each channel outputs whether the sensor is seeing a gap or not.  The Optipac, Optiwiz, or hacked mouse board these are connected to is what converts the quadrature signal to amount (and direction) and sends that to the computer.
Robin
Knowledge is Power
Hawk Daddy
« Reply #3 on: June 29, 2007, 01:37:49 pm »
Well it's not going to a computer, its going to a multiboard.  Thats why I was asking. And the manual that came with the board has those as what wires it needs to be.
Hawk.
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #4 on: June 29, 2007, 01:50:36 pm »
I am interested in finding out this info as well...I am going to hook a centipede TB to a multiboard...the multigame board uses the JAMMA harness.  How do I hook it up...am I going to need to get an Optipac or something or can I wire the TB directly to the JAMMA harness?
Hawk Daddy
« Reply #5 on: June 29, 2007, 02:40:44 pm »
From my understanding it's not going to need any type of converter, it should just hook straight up to it.  I just have to figure out the correct way to hook it it, I plan on messing with it tonight, hooked to a computer monitor.  I'll post my results.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Hawk Daddy
Re: Happ trackball pin out? Mybad, I need an Imperial pinout.
« Reply #6 on: June 29, 2007, 02:44:39 pm »
Um yeah how about an imperial, cause I thought it was happ, guess what, I was wrong.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Crowquill
  • Last login:December 03, 2021, 05:02:15 pm
Re: Happ trackball pin out? My bad, Imperial, is the one that I need.
« Reply #7 on: June 30, 2007, 05:28:10 am »
Looks like These Wico's use pretty much the opposite of Happ's pinouts. Those aren't the standard Wico/Imperials that you commonly see, though. I'm almost positive that they use the same pinout on the optical boards as Happ/Atari.
BTW, anyone else think it's odd that Wico's webpage is up still?
You could always go THIS ROUTE.
As far as wiring it to the harness goes, it's hard to say. Some JAMMA games used player 1's up,down,right,and left pins for trackball input, most had a seperate connector on the game PCB for it. Reading the game manual is probably the only way to tell. I'm still not sure how to connect the trackball to my Simpsons Bowling PCB since I can't find a manual or anyone that knows.
BobA
  • What Me Worry?
« Reply #8 on: June 30, 2007, 05:48:24 am »
Here is some color info for the pinouts on the wico/imperial trackball that I hacked about 5 years ago.
http://www.members.shaw.ca/bakaye/tballhack.htm
FrizzleFried
    • Idaho Garagecade
« Reply #9 on: June 30, 2007, 12:32:13 pm »
The multigame boards accept trackball input through the Player 2 wires of the JAMMA harness.  4 wires - 2 for X and 2 for Y....plus I assume the TB has to be hooked up to a +5V and ground.
Hawk Daddy
« Reply #10 on: June 30, 2007, 12:59:23 pm »
I've got the part that connects to the optic boards, I need the pinout for the connector, because thats where I have to hook up the new stuff, I've got the ground down, thats the easy part, it's universally black, most of the time.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
BobA
  • What Me Worry?
« Reply #11 on: June 30, 2007, 01:12:59 pm »
Molex Connector Wiring
(blk)        Gnd         1              4              Vdir         (green)
(red)        +5V         2              5              Hclk        (blue)
(yellow)  Vclk        3              6              Hdir        (brn)
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #12 on: July 01, 2007, 10:38:19 pm »
Go with BobA's color coding and you'll have it.
I'll add that some trackballs use purple in place of the brown, but the pinout on the connector is the same, at least with every Happ, Wico, and Betson/Imperial trackball I've dealt with so far.  Also later Atari units, but not the older ones like the giant Missile Command / Atari Football type balls.  GGG Electric Ice balls should match as well, I dunno about the Ultimarc unit as I've never had one.
Hawk Daddy
« Reply #13 on: July 07, 2007, 02:47:06 pm »
Is H=Y, and V=X or is it the other way around?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
BobA
  • What Me Worry?
« Reply #14 on: July 07, 2007, 04:10:08 pm »
When I made up the drawing my ref was H=Horiz=X and V=Vert=Y
Hawk Daddy
« Reply #15 on: July 07, 2007, 05:36:34 pm »
Got cha thanks man.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
