| Main > Main Forum |
| coin mechanism |
| << < (2/2) |
| superbigjay:
hello dannyyy. I've found this pdf. www.alca-coin.com/files/05%20R6.1%20eng.pdf That coin mech is programmable and very flexible. But it will be difficult to hook up... It can accept different coin/token and you can assign a value to each of them. The thing is that it;s using its 10 pins connector and some sort of serial encoding to inform the "money board" what value was inserted... goodluck, Jay |
| superbigjay:
this is the same website with all the products they support... http://alca-coin.com/eng/index25dc0.html?p=pro&n1=menu this is probably the pdf that has the validator info: http://alca-coin.com/files/05%20R6.1%20eng.pdf have fun... >:D |
| MonMotha:
The manual claims that there is a 4 pin connector at RS-232 levels. This could be hooked up to a standard PC serial port with a suitable (possibly custom-made) cable. Documentation for the protocol it speaks is supposedly on their website, but I have not looked. They seem to call this "master mode". Once you have it hooked to your serial port, you would then simply run a program in the background to monitor the serial port for the coin device to speak and take appropriate action (such as artificially generating a keypress) when it does so. This would be much easier than using the other interface on there. If you don't have a serial port, one of the USB to RS-232 serial adapters should work for this purpose as it appears to actually be sending serial data, not bit-banging the handshaking lines. |
| Green Giant:
Oops, wasn't thinking of a meter at all. Had a brain fart there. What I meant to say was an oscilloscope. Figured this coin mech might send varying signals that could be read by an oscope. Out of school for a little while and you start forgetting everything. |
| dannyyy:
thanks for the replies. I'll try to figure out what the easiest option is for me. If I can get it to work, I'll let you know. greets, Dannyyy |
| Navigation |
| Message Index |
| Previous page |
