Author Topic: 20' of brand new 5/8" red T-molding for sale  (Read 1446 times)
jasonbar
  • Last login:July 30, 2023, 02:52:55 am
  • Dr. Inferno
    • The Infernolab
« on: June 22, 2007, 11:36:55 pm »
I got some T-molding (http://t-molding.com/store/product.php?productid=40&cat=17&page=1) to spiff up my X-Arcade trackball unit, but it turns out that they use funky T-molding that has a much wider slot.  The stuff I just got from t-molding.com doesn't stick in--not even close.  :[
So, I paid $15.36, including shipping, for 20' of 5/8" red T-molding.  Anybody want to buy it?  I'd like to break even, but I'll entertain offers.
Thanks,
-Jason
Stobe
  • Trade Count: (+17)
  • Last login:January 23, 2024, 05:08:05 pm
Re: 20' of brand new 5/8" red T-molding for sale
« Reply #1 on: June 23, 2007, 12:10:03 am »
Not to deter from your BST offer, but did you considder running a bead of hot glue along the groove?
-Stobe
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #2 on: June 23, 2007, 12:43:09 am »
Hmm--interesting idea--no, I hadn't tried that.  I did consider jamming something in there to help fill up the gap (thin cardboard, cloth, etc.) but I didn't think I'd get the same "grab" that the little tines/barbs on the backside of the T-molding get.
Is the hot glue trick a tried & true hack?
Thanks,
-Jason
shardian
« Reply #3 on: June 23, 2007, 07:55:12 am »
Thanks,
-Jason
Oh it will definitely work. And the best part is the t-molding will still be removable.
Stobe
« Reply #4 on: June 23, 2007, 09:26:55 am »
Thanks,
-Jason
I've used it several times with good results.
Example:
To myself:  "I know I can get these last two lengths cut with this dull  slot cutter!"
...after the cuts are done...
"Opps, looks like I just used a wood burning blade to cut the slots:  :)
-Stobe
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #5 on: June 23, 2007, 01:45:06 pm »
Thanks--I'll give it a whirl on the back side of the trackball unit for a test (I don't want to totally strip off the existing stuff in case I can't get the new stuff to stick & line up well).  After thinking more about it, I might also try jamming cloth in there (folding it over the insertion portion of the T-molding & tapping it in w/ a mallet) before busting out the hot glue.
Thanks,
-Jason
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #6 on: June 26, 2007, 11:42:02 am »
Thanks for your help, Stobe.  I got the red t-molding on my little X-Arcade trackball this weekend, using hot glue.  It worked *almost* perfectly.  There are a few spots where the t-molding isn't quite flush w/ the edge of the wood, especially around corners (even though I did trim away the inserted portion of the t-molding at corners).
Most parts took 2 tries: fill the slot w/ glue, jam the t-molding in, hold for a while, watch it pull back a little when I remove pressure, yank it out so that it makes a bunch of snot bridges when I pull it away, coat the t-molding, re-smush, hold, then it was usually ok.
Notes:
1 - It's tough to get dried hot glue out of textured vinyl laminate cover--wipe it off when it's still wet!
2 - The slots routed into the X-Arcade trackball are *much* wider than the barbs on the 5/8" t-molding from t-molding.com!
Pictures will follow, eventually, when my cabinet is farther along...
Thanks,
-Jason
Stobe
« Reply #7 on: June 26, 2007, 01:18:28 pm »
Glad to be of help, although I learned that trick from this same website, so someone else deserves the credit.
And I'd hurry up and trademark the term "snot bridges" before some semi-talented punk band snatches it up!
-Stobe
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #8 on: June 26, 2007, 01:33:07 pm »
My buddy already called dibs on "Nose Grease."  I can see those 2 bands touring together...
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #9 on: June 27, 2007, 12:48:33 am »
Oh, PS: 15' of brand new 5/8" red T-molding for sale!!!  ;D
