Author Topic: LCD display for marquee, anyone ever done that?  (Read 6328 times)
Lectoid
  • Last login:September 04, 2015, 02:15:40 pm
« on: June 21, 2007, 10:06:12 am »
Has anyone ever thought about having a custom LCD sign made and making that a marquee.
Think about it, you could have it display whatever game you are playing at that moment. Or display anything for that matter, scores, lives, etc.
Lectoid
Re: LCD display for marquee, anyone ever done that?
« Reply #1 on: June 21, 2007, 10:08:51 am »
I should note, I don't mean the monochrome LCD displays people use on their cabinets. I am talking about like if you took an LCD TV and cut the top and bottom off (yes I know that's not possible). Full color display.
Lectoid
« Reply #2 on: June 21, 2007, 10:20:15 am »
I just measured my 14.1" laptop screen and it's 7.5 inches high by 12 inches wide. If you just stuck two of these side by side, you'd have an average marquee size.
Interesting. Other than that, I am not finding anyone that will make custom LCD monitors.
« Reply #3 on: June 21, 2007, 10:20:47 am »
Haven't seen it, mostly because as you mentioned, they don't come in a reasonable shape for a traditional marquee.  People have used BetaBrites, I believe.
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
« Reply #4 on: June 21, 2007, 12:28:34 pm »
Possibly a cheap option is to take one of those digital picture frames.  Load it up w/ screenshots from games and put it on slideshow mode.  You can then surround it on the sides with regular marquee material (to accomodate the size difference).
It'd probably look like ass, but it's doable.
« Reply #5 on: June 21, 2007, 01:37:45 pm »
They're pretty much just 4x6 or 5x7, though... nothing like what someone would use for a marquee.
SavannahLion
« Reply #6 on: June 21, 2007, 01:47:21 pm »
I could swear that I posted this already. Hhmm..
In the Examples section, there's a few cabs that use LED sign marquees. I think it looks like crap, but whatever.  :dunno
I had the exact same thought myself. I was at a casino when I noticed that some of the rotating marquees were actually very wide low/medium resolution LCD screens. I figure 10" tall and 4' wide. I Googled around a bit and found a promising manufacturer (didn't keep the link though) that produces LCD signage in different sizes. The smallest being like a large Marquee. It's mad money though, about a two or three thousand for the most basic.
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« Reply #7 on: June 21, 2007, 02:12:00 pm »
Ditto, unless of course you camoflouge the fact that an LCD would be too high by framing it in somehow. You can decase it (which can be done because I've done it), frame it somehow and display your marquee within the framed area only. May have potential. Love to see it if you go that route.
This plan is so perfect, it's retarded. -- Peter Family Guy
« Reply #8 on: June 21, 2007, 02:30:25 pm »
Why bother with that route, though?  Your cabinet would still have to have the marquee area big enough to house the whole thing, and at that point, you're wasting LCD real estate.  I'd say if you're going to use a larger LCD, just redesign the cab to accommodate it nontraditionally.
GAtekwriter
  • Last login:July 16, 2011, 09:55:44 am
« Reply #9 on: June 21, 2007, 02:33:49 pm »
One possibility is hacking the JuiceBox... that little toy LCD screen for kids.
Here's an instructable.com link and I know I've seen other links where people have taken these apart to create their own displays... might be possible.
http://www.instructables.com/id/E1MF1CGOQLEXCFFOXD/
Jim
« Reply #10 on: June 21, 2007, 02:36:31 pm »
Hrm... very small screen for the price, but you'd be able to do more than with an LCD pictureframe.
GAtekwriter
« Reply #11 on: June 21, 2007, 03:38:34 pm »
I'm guessing you'd need to have 6 or 7 of these, side-to-side, to make one marquee sized display.  At $70 each, that would be a high-priced solution but I imagine it could be done.
Jim
Dervacumen
  • Last login:February 13, 2019, 10:11:11 pm
  • Home of Three Squares dice game
    • Beaker Games
« Reply #12 on: June 21, 2007, 05:24:41 pm »
Did the same thing a couple years ago and when I saw the price range I decided on a $13.00 pre-printed generic one from mamemarquees.com.
Bringing to life a child's imagination.
ark_ader
  • I glow in the dark.
« Reply #13 on: June 21, 2007, 05:34:02 pm »
Why bother with that?
Have your marquees on a roller like a blind and have it scroll to the chosen game you are playing (obviously your options are limited) but maybe some trigger like mamehook which can drive a small motor or the like.  I'm sure some of you coders out there can bang something to gether pretty quickly.
Its very do'able.
So lets see who does it first!!!
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #14 on: June 21, 2007, 08:00:08 pm »
I have been brainstorming on changeable marquee options for a long time now and ended up getting two 15" lcds yesterday to mount flat and vertically in the back of my upright "Arcade Paradise 2" - shaped cabinet.  I tried a few things last night but I can't seem to get the optics corrected in the small space above my main crt.  I think I may have to use an LCD for my main monitor as well, just so I can have a fixed stretched image the shape of the marquee.  It has been a nightmare trying to research for examples of other DIY projects like this.  Google mostly comes up with patents, not so much consumer products.
I had thought about the banner/tape method with stepper motors.  Then, alternatively, of a system for multi-game selection via the marquee itself.
Instead of the marquee changing mechanically via the game selection, one could manually roll or replace the marquee, which could be identified by Reactivision fiducial (using a camera) or via a barcodes setup.  Then this identification could be sent to an app to launch that specific game.
If anyone knows how to magnify the image and refix the viewing angle like a rear projection TV please post or PM me to help me find proper optics.
vrf
  • Last login:October 13, 2017, 10:11:54 pm
    • Pixelbox
« Reply #15 on: June 22, 2007, 03:17:12 am »
What if one were to integrate a small LCD into a larger marquee design, like on one side? It would take a pretty clever design, but if you got the colors and integration right, it could work well. Maybe the marquee theme could be a generic "arcade classics" kind of thing... and then the LCD area would be used for more specific artwork from the original cabinets.
SavannahLion
« Reply #16 on: June 22, 2007, 03:31:58 am »
Dude... This is the 21st century. Go build a Steam Punk cab if you want to do that.
NickG
  • Dig.
    • My Projects Page
« Reply #17 on: June 22, 2007, 08:10:10 am »
That's like my "Plan B" for mine.  A big "Now Playing" Neo-Geo style Marquee (with the LCD as the mini-marquee).  Going to try to make sure I can use the touch screen if I do it that way.
« Reply #18 on: June 22, 2007, 09:07:30 am »
I'd say a more realistic use at this point would be a small one next to or embedded in the CP that displays relevant info as a game loads... control scheme, hi scores, etc.
NickG
  • Dig.
    • My Projects Page
« Reply #19 on: June 22, 2007, 09:17:03 am »
Sometimes you have to think outside the CP...         ;)
« Reply #20 on: June 22, 2007, 09:21:32 am »
You also have to use technology reasonably available... there just aren't LCDs that really fit the traditional marquee shape yet.
SavannahLion
« Reply #21 on: June 22, 2007, 09:54:36 am »
That's probably what this guy was planning on doing with his panel.  ;D
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #22 on: June 22, 2007, 01:01:24 pm »
what is the standard markee size?
come to think of it.. the best way to do what your thinking about doing would be with a cheep projector, from behind.  you could then have it whatever size you wanted... i dunno how bright it would actually be tho,
« Last Edit: June 22, 2007, 01:02:56 pm by steveh »
« Reply #23 on: June 22, 2007, 01:04:22 pm »
You'd never get a reasonable focus of beam for something like that.
shorthair
« Reply #24 on: June 22, 2007, 01:37:18 pm »
I thought of this some months ago but with the idea of digital paper. Not here yet, but should be. Could use it for side art, etc.
« Reply #25 on: June 22, 2007, 01:45:06 pm »
Before that I thought of using a tiny Jenny McCarthy from 1995.
shardian
« Reply #26 on: June 22, 2007, 01:46:04 pm »
I keep waiting for someone else to post it, but noone did so here is McCoy's Varsity Club machine:
It uses a dual monitor setup, and technically the top monitor acts as an interactive marquee.
shardian
« Reply #27 on: June 22, 2007, 01:47:50 pm »
Sure you could do that with a tv projection lens and a small scale lcd, but the resolution, contrast, etc would be horrible.
« Reply #28 on: June 22, 2007, 01:51:07 pm »
That's pretty much what I meant.  You'd end up with something like a viewmaster projector quality.
ark_ader
« Reply #29 on: June 22, 2007, 04:52:14 pm »
Ok how about a PS1 LCD with a magnifier, angled so it fills a rectangle sized marquee area.
It might be blurry but its an idea.
shardian
« Reply #30 on: June 22, 2007, 04:53:59 pm »
If you are gonna do that, just use a widescreen pc lcd.
NickG
  • Dig.
    • My Projects Page
« Reply #31 on: June 22, 2007, 09:14:29 pm »
Using an lcd with only a magnifier lens get the image large enough , but only from a viewing angle of near 90° from the magnifier.  At other viewing angles,  The image is shifted to the side and/or distorted.  The image must be both magnified and re-diverged and diffused at the viewable marquee surface.  What type(s) of lense(s) ar required at this point?
shardian
« Reply #32 on: June 22, 2007, 11:15:58 pm »
You can pick up a page size fresnel lens at an office supply store for around $8 to play around with.
NickG
  • Dig.
    • My Projects Page
« Reply #33 on: June 23, 2007, 01:22:59 am »
I have two A-size page magnifier size fresnels from inside an old broken Barcodata2100 LC projector.  I was messing around with them the other day; I tried to magnify with the first and diverge with the second but I could not seem to make that work.  (I will try again later and use the fresnel only for the front screen and perhaps magnify by other means.)
After I saw this thread , I became excited about the idea again, and shoved my little olympus VP-1 into the speaker area of my cabinet.  using a broken hand mirror and the mirror out of my old broken projector I was able to project a good mockup of a marquee onto some plain white biology paper cut up in the marquee area.  It's maybe a start, but I stilll have to hold the mirror out further than the back of the cabinet.  Back and forth I think I need to recover approximately one meter if all components are to fit inside the cabinet.  With this setup the throw length is too great for only one or two reflections.  Here are some caps of my quick and sloppy projector marquee experiments:
Yesterday I was manually holding two mirrors up to reflect the second desktop image to the marquee.  I was able to get fairly close to the cabinet but I had keystoning.
Today I prepared (somewhat) a marquee image and just set it as my desktop.  Then I held just one mirror up (a bit further out.)  Little to no keystoning this time.
I want to try using two vertical mirrors but I am not sure if the image can be reflected back and forth in this manner without doubling up upon itself in such a small space.  Also, I am mostly certain that I can not compensate for the throw length with the current projector lense...
In case anyone can not deduce, the dark vertical lines in the marquee are from the overlaps in the paper sheets I had slopped up there.
Edit:  I was thinking about this again this morning.  Is is all so simple now.  Going to plan F.  I have to shotgun two projectors inside the cabinet; side-by-side.  The two projected images will only need to be half as wide as the single projection I have tried before.  Therefore the throw length can be shorter and maybe I can fit everything into the cabinet.  The composite (stitched) image will still be the full size of the marquee.  I am thinking about buying another identical projector just to try this out in the cabinet, and building my own custom projector later to reduce the heat, noise and power requirement.  Then I can use the off-the-shelf projectors for movie night.
« Last Edit: June 23, 2007, 09:34:36 am by NickG »
Flack
  • Last login:January 26, 2021, 06:33:21 pm
  • The Commodork
    • Rob's Homepage
« Reply #34 on: June 23, 2007, 09:51:34 am »
My first thought was, why not use two or three flat panel monitors and arrange them like a Dragon's Lair marquee?
.xX Flack Xx.
« Reply #35 on: June 23, 2007, 06:03:40 pm »
Doesn't address the lack of an LCD in that rectangular shape.  Can't have three if you can't have one.
tommy
« Reply #36 on: June 23, 2007, 08:10:51 pm »
I'm sure you could get a good size screen and cover up the parts of the screen you don't need and make it fit a normal size marquee opening, as long as you can move the image to where you want it on the screen.
brandon
  • Last login:October 19, 2023, 03:08:43 pm
  • I <3 arcade games.
« Reply #37 on: June 25, 2007, 03:28:10 am »
wouldn't 3 in a row make a rectangular shape? :)  The 4:3 aspect ratio times 3 would be be 12:3.  IOW, 4 to 1 which is much skinnier than most marquees I think.  The problem is the spaces between then monitors..
vintagegamer
  • Last login:November 16, 2014, 07:41:40 am
  • Seasoned Arcade Survivor.
« Reply #38 on: June 25, 2007, 08:52:03 am »
Maybe I'm showing my age here, but when I brought my Ms Pac and Asteroids machines home, I was so proud of the fact that not only were both marquees in tact, but they both lit up and looked great.  That part of the machine is one of the foundations of the unit in my book, since you were always looking for that familiar marquee of your favorite game in a foreign arcade (back in the day).
I wouldn't think of tearing them out to replace them with anything else.   Now, if I had a machine that was missing the light hardware and/or the marquee, maybe I'd consider something like this-
« Reply #39 on: June 25, 2007, 08:55:51 am »
It would, yes, but then you have to feed synced split images to three different monitors... and even a decased monitor has housing that would introduce gaps between the three screens.
Tommy, your suggestion was mentioned above... you'd have to do that in a nontraditional shaped cab to fit the screen.
