Author Topic: Any soldering needed with connecter crimps?  (Read 886 times)
Chris2
  • Last login:March 29, 2023, 09:34:34 am
  • Servin' up Bacon.
« on: June 20, 2007, 11:30:47 pm »
Basically what it says. Do connecter crimps still need to be soldered to the pins on a microswitch?
"Do you like Huey Lewis and the News?"
  • Last login:Yesterday at 07:54:28 pm
Re: Any soldering needed with connecter crimps?
« Reply #1 on: June 20, 2007, 11:42:48 pm »
No.
fjl
  • Pixels Rule!
« Reply #2 on: June 21, 2007, 01:09:03 am »
If you are talking about those Female Quick Disconnects, then no. But depending on how you crimp them, its possible for the insertion part to open slightly causing the connector to not get good contact and can slip off. Easily fixed by bending the connector back carefully with pliers.
SirPeale
  • Green Mountain Man
« Reply #3 on: June 21, 2007, 02:35:14 am »
Not if you do it right, and use the correct size terminal.
NightGod
« Reply #4 on: June 21, 2007, 04:19:18 am »
The whole idea behind them being a crimp connector is that you don't have to solder them.
It's kinda like asking if you have to lick the back of a self-adhesive stamp.
Chris2
  • Servin' up Bacon.
« Reply #5 on: June 21, 2007, 09:54:42 am »
ah. Alrighty then.
« Reply #6 on: June 21, 2007, 09:58:29 am »
Once you're a reasonable solderer, it takes about the same amount of time to crimp as it does to solder.  Maybe less if you're doing a lot of them at once.
