Author Topic: running mame from dos prompt on winxp  (Read 1622 times)
taskmagee
  • Last login:June 21, 2007, 05:48:25 pm
« on: June 20, 2007, 08:39:17 pm »
I'm trying to set up dos to start running mame when i open it from windows xp. I know it can be done on the older windows versions through the dosstart.bat file. I can't seem to figure it out for xp. Can any one help with this.
Thanks,
Kenny
severdhed
  • RIP Dinosaur Hippo
Re: running mame from dos prompt on winxp
« Reply #1 on: June 20, 2007, 11:36:52 pm »
i'm not sure i follow you.
are you trying to get mame to run as soon as windows starts?  or something else?
ahofle
    • Arcade Ambience Project
« Reply #2 on: June 21, 2007, 12:23:40 am »
Why not just run a MAME batch file instead of running a DOS prompt and then auto-starting MAME?  ???
You can't 'Shut down to DOS prompt' in XP like in win95/98 if that's what you are talking about.
It might help if you describe what exactly you are trying to accomplish.
taskmagee
« Reply #3 on: June 21, 2007, 05:48:25 pm »
I want to run mame in a dos only system. I want mame to start up as soon as you turn on the computer, but before I put it in a spare computer that I have, I want to make sure I can get it to work.
  • Last login:May 03, 2024, 11:58:33 pm
« Reply #4 on: June 22, 2007, 06:14:37 am »
The only way you can do that is to dual boot your system or make a bootable floppy disc or cdrom with dos (and mame, roms ect..) on it.  You cannot run dos within xp because xp doesn't have a dos mode.
Buddabing
« Reply #5 on: June 22, 2007, 05:21:42 pm »
Your first post requests something totally different from your second post. Which do you want?
Please read the wiki!
shorthair
« Reply #6 on: June 22, 2007, 06:13:38 pm »
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #7 on: June 25, 2007, 02:49:59 am »
Taskmagee, WinXP is fundamentally different from Win95/98. The earlier OSes were a graphical interface built on top of a DOS platform. It can be argued that Win95/98 aren't even OSes but very fancy applications that run in DOS.
WindowsXP is an actual OS and is not DOS based. Microsoft threw in a DOS emulator which you can run to start up command line programs, but because it doesn't run on DOS, there is no way to get a "DOS-only" version of XP, or boot to DOS etc. XP is simply not built that way.
If you want / need to run pure DOS, boot into DOS etc, you need to go back to Win98.
SGT
  • Last login:April 17, 2023, 08:29:42 pm
« Reply #8 on: June 25, 2007, 09:52:18 am »
If you only want to run pure DOS why not just install DOS instead of win98.
Anubis_au
« Reply #9 on: June 25, 2007, 10:35:01 pm »
If he can find DOS. 98 is easier to get your hands on. But, agreed...
