May 07, 2024, 12:13:19 pm
Now I have a decision to make. That is 50 minutes away. Time to think. It looks like it won't fit in my doorway to my room.Thanks for the heads up.
thats not the kinda Dynamo Cab I thought it was, that looks like the old style of Tekken Cab, this what I thought you were talkin about:
That one you linked is commonly called a Z Back. I have an HS-27, I don't recall ever seeing a game in the style cab in that auction.Does anyone know the model #?
Quote from: tomsurfnj on June 18, 2007, 02:27:17 pmNow I have a decision to make. That is 50 minutes away. Time to think. It looks like it won't fit in my doorway to my room.Thanks for the heads up.If you can't fit in a Dynamo you can also rule out a large % of arcade cabs.
I did. Those are only a few inches wider than a standard 19" dynamo. There is a reason the CP is removable. Remember the usual standard dynamo can often fit a 25" as well.
