Author Topic: WTB: Carriage Bolts for CPs  (Read 914 times)
Luigi
  • Collecting/restoring cabs
« on: June 18, 2007, 09:13:48 am »
Hi guys :)
I'm searching for some carriage bolts in small size for fixing controlpanels.
I mean these:
Here in Germany I can only find those screws in larger sizes (5mm and more) but I need small ones (3-4mm) for the controlpanels.
Can you tell me if and where you guys get them from?
Thanks.
shardian
Re: WTB: Carriage Bolts for CPs
« Reply #1 on: June 18, 2007, 09:19:47 am »
The byoac vendors sell black ones in two lengths.
Luigi
« Reply #2 on: June 18, 2007, 09:45:50 am »
I've been looking at divestar. edit: divemaster  ::)
Happ black powder coated carriage bolts .25 each these are hard to get
  Carriage bolt 10-24 x 3’’ black
 Carriage bolt 10-24 x 2’’ black
To be honest, I don#t know what those measures mean? 3" and 2" ist the length I guess.
But what means 10-24? What is the diameter of the screws?
shardian
« Reply #3 on: June 18, 2007, 10:03:30 am »
The 10-24 has to do with pitch and thread count. I believe the actual diameter of the thread portion of these is around the 3/16" you are wanting. Either way, they are direct replacements for the control panels I have done.
Havok
  • Trade Count: (+17)
« Reply #4 on: June 18, 2007, 10:07:48 am »
You are correct - the 3" and 2" is the length. These are the standard diameter bolts for mounting joysticks and such. About the 10-24: The first number is the diameter, and the second is the threads per inch. There is a formula for determining what the actual diameter is, but a 10 is about 3/16 of an inch.
Make sure if you order from DM that you specify you want the nut as well - I ordered a bunch a ways back and only got the bolt...
*Edit*
Shardian is a faster typist...
« Last Edit: June 18, 2007, 10:20:23 am by Havok »
Luigi
« Reply #5 on: June 18, 2007, 10:12:23 am »
Thanks. You are right....I need the nuts, too. Hehe, that would be "funny": I'd have the bolts but not the nuts :D
So 3/16" is ~4,7mm...hmmm...that's quite a lot. The ones I have are smaller....I will measure them....
