Main > Main Forum
buttons through gameport?
eagle00789:
it's infact a right on joy 1 but this schematic is going inside my pc inside a bracket actually, so that i can control winamp (and other music players) with it and the pot-meter is for volume control.... (the five buttons are for: Previous song, Play, Pause, Stop, Next Song)
eagle00789:
p.s. i'm not using the 2n3906 transistor but the 2n3905
eagle00789:
i've got it working and i will post a working schematic later, because to get it working i had to modify my own made schema a lot...
BobA:
Glad you got it going. Any info that you can provide will help someone down the line.
:applaud: :applaud:
eagle00789:
Some wires have new connection points. but if you look closely, you can see that i had to hotwire pin 9 11 and 13 to get the thing to be seen by windows. if you leave that bit out, windows doesn't recognise it. also, you can add leds by putting the led over a button (only the below 4 buttons and not the top button)
