Main > Main Forum
NESVS control to PC Help!
SirPeale:
--- Quote from: rampy on April 21, 2003, 09:08:03 am ---
--- Quote from: chuggy on April 20, 2003, 11:48:33 pm ---I did find the KEYwiz websight, and 26 bucks fits any budget. Have you used this before, and is it an easy way of doing this? thanks for your other responses.
I've used the middle tier one (the one with the terminal barrier thingie)... and am pretty darn happy with it... It's much easier/better than my sidewinder hack that was in there previously.
THe cheapest key wiz does require some very rudimentary soldering though (there's no barrier strip/screw terminal thingie)
But if you were considering a keyboard hack or a gamepad hack, you'd be soldering anyways...
Save yourself some agrivation. Buy the standard model. For seven bucks more, you can't beat it.
chuggy:
cool will do
thanks again
