Main > Main Forum
NES as console?
Pages: << < (2/6) > >>
JamesMolloy:
You can get smooth NES emulation on a 300Mhz and 64mb RAM if you track down an old emulator. The new ones have all those natty filters that look crap anyway.
The real NES isn't a good 2nd hand option. The cartridge connectors are really cheap which results in all the puffing and resetting.
shmokes:
What about Super Nintendo emulation?  Anyone know offhand what minimum system specs are?  I suppose I could look it up, but if SNES emulation would run well on that 500 Mhz via mini-itx board I might have to consider including that functionality (though I would obviously need to use different controllers).
chuggy:
WOW,
First of all thanks a ton for quick response. secondly, is there any guides out there for wiring a NIntendo VS control panel to a PC? Remember im new! thanks again.
Snarbald:
My friends and I used to run SNES emulators fine on anything as low as a p166 back in the day. Had N64 emulators running (crappily except for starfox) on a pII266.
Druin:
I used to run Nesticle (NES) and Massage (Master System/Game Gear) with no problems on P100 64mb   back in 97/98
SNES was rather unplayable though.
For help wiring the control panel over, depends what method you're going to go with, a real console or a PC with emulation.
If you're doing PC emulation then you may be getting into wiring up keyboard encoders, which is easy to do.
Go to full version
