Author Topic: q-bert 45 degree.UM file error w/screenshot  (Read 4009 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: June 12, 2007, 06:02:40 pm »
I tried to play q-bert the other day and when I launched it I received a message that it could not find a (45 degree .UM file)??  I have one of the 45 degree files .ugc but I guess there is another one I need?  Any idea's??
« Last Edit: June 13, 2007, 03:59:57 pm by squirrellydw »
I b**ch. People listen!!
Aurich
  • Last login:September 12, 2021, 01:34:32 am
Re: q-bert 45 degree .UM file for Utimarc Ultra stick?
« Reply #1 on: June 12, 2007, 07:25:15 pm »
Does the name of your 45° map match the name the q-bert.ugc has?
squirrellydw
« Reply #2 on: June 12, 2007, 07:32:42 pm »
is the .um file the map?  :dunno  If so I don't have a um file for q-bert.  All the other ones work though.
squirrellydw
« Reply #3 on: June 13, 2007, 10:41:56 am »
here is the error I am getting
« Last Edit: June 13, 2007, 10:45:26 am by squirrellydw »
Donkey_Kong
    • CNC Machines
« Reply #4 on: June 13, 2007, 11:47:25 am »
Yikes!!  :o  The analog setting for Qbert would not be good!  ;D
squirrellydw
Re: q-bert 45 degree.UM file for U360 error with pic attached
« Reply #5 on: June 13, 2007, 12:59:44 pm »
Can anyone post this file or send it to me?  squirrellydw at gmail dot com
fjl
  • Pixels Rule!
Re: q-bert 45 degree.UM file error w/screenshot
« Reply #6 on: June 14, 2007, 02:52:07 am »
Why not just make a new one?
squirrellydw
« Reply #7 on: June 14, 2007, 09:46:57 am »
how do I do that?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: June 14, 2007, 04:54:48 pm »
The message is being generated by UltraMap when trying to download the appropriate UGC file to the UltraStik 360. The UGC file contains maps for each joystick and in this case the one mentioned in the error is missing. This is a standard map so if you can drop me an email I'll send it.
andy@ultimarc.com
squirrellydw
« Reply #9 on: June 14, 2007, 05:09:06 pm »
email sent, thanks
squirrellydw
« Reply #10 on: June 15, 2007, 05:40:45 pm »
OK, Andy says it's not a standard file and he doesn't have one.  He said I could try to rename one so I m going to try that but if that doesn't work can some please post one or email it to me.
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #11 on: June 16, 2007, 07:48:17 pm »
There is a tool out there (on the Ultimarc website from memory) that you can use to make your own maps for the U360s.
All you need after that is to know how the map should look for a 45 degree rotated game like Q-Bert.
Luckily, the review of the U360s on the Retroblast website gives you precisely that:
http://www.retroblast.com/reviews/Ultimarc_Ultrastick_0925006-01.html
I'd help more if I could. I've already purchased two U360s from Andy but I am *months* away from using them yet... otherwise I'd have emailed you a map :P
But hopefully this is enough to get you going.
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
« Reply #12 on: June 16, 2007, 10:04:12 pm »
Fatfingers plug-in for Mala includes a qbert.ugc map file:
# This is an Ultimarc UltraStik Game Configuration file
UltraStikGameConfigurationFileFormatVersion=1.0
UltraStik1MapFile=4-Way, 45 Degree Angle
UltraStik2MapFile=4-Way, 45 Degree Angle
UltraStik3MapFile=
UltraStik4MapFile=
This is what's calling the UltraMap app and it points to a file "4-Way, 45 Degree Angle.um" which it expects to find wherever all your other UltraMap map files are.
I think Andy's 45 Degree Map just has a different filename.  Either rename it to match the qbert.ugc map, or modify the filename in qbert.ugc to match Andy's and you should be good to go.
« Last Edit: June 16, 2007, 10:08:22 pm by Dmod »
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
« Reply #13 on: June 17, 2007, 09:12:16 am »
Sorry for the slow response, I have been out for a week.
Posted below is the contents of the 4-Way, 45 Degree Angle.um file that needs to be in the Maps subdirectory of the UltraMap installation dir.  Usually this is C:\Program Files\UltraMap\Maps.
Enjoy.
MapFileFormatVersion=1.0
MapSize=9
MapRow1=W,W,W,W,*,N,N,N,N
MapRow2=W,W,W,W,*,N,N,N,N
MapRow3=W,W,W,W,*,N,N,N,N
MapRow4=W,W,W,C,C,C,N,N,N
MapRow5=*,*,*,C,C,C,*,*,*
MapRow6=S,S,S,C,C,C,E,E,E
MapRow7=S,S,S,S,*,E,E,E,E
MapRow8=S,S,S,S,*,E,E,E,E
MapRow9=S,S,S,S,*,E,E,E,E
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
squirrellydw
« Reply #14 on: June 17, 2007, 09:57:12 am »
thanks
