Main > Main Forum
Complete n00b, need some starting advice
OSCAR:
--- Quote from: rampy on April 20, 2003, 05:29:37 pm ---Sasquatch, I might be off the mark.... but i believe that mounting plates intended purpose is for retrofitting the new happs 4 way ball top to fit on to the old ms pac/pac style mounting...
not necessarily for mounting it in a wood panel. although that's not to say it couldn't be mounted with that plate in wood... and i'd like to see it if anyone's done it (with that plate, not home made plate) in wood...
*shrug* just a thought - I could and may well be wrong
rampy
Correct, rampy, that is the intended application for the adapter plate. However it can be used for a wood mount, just like the joystick mounting plate for my restrictors. FYI - my joystick mounting plate will also allow you to use this particular joystick for a wood mount, too, but it has the 4 extra holes for the restrictors.
Sasquatch!:
Ah crud, I'm wrong!
--- Quote from: OSCAR on April 20, 2003, 05:56:20 pm ---However it can be used for a wood mount, just like the joystick mounting plate for my restrictors.
Huzzah, I'm right! Unintentionally, but, well...er, yeah.
rampy:
--- Quote from: Sasquatch! on April 20, 2003, 08:15:37 pm ---
Ah crud, I'm wrong!
OK... i just think the detent in the middle would be annoying (although the original ms pac has that, so...) a custom/simple mounting plate would work better in my opinion...
*Shrug* well it made for an interesting discussion anyways... It's good to know though.
rampy
shmokes:
I'll probably just pick up Oscar's plate when I place my DOT spinner order. Well...I suppose I should check prices before make that decision, but I suspect that'll be my course of action. I'm not sure whether I'll leave the holes visible for the restrictor plates or not. I'm planning on laminating my CP and countersinking everything so no screws or anything show (well, I might let buttons and joysticks show through the top). God, so much to think about. I guess I should make the extra holes and pick up some restrictor plates. I'll just have to figure it all out when it gets here and I can visualize better.
Does anybody want to fly out here at your expense and help me build this thing ;) ?
*edit* sorry about hijacking this thread...this stuff has nothing to do with the original topic.
