Author Topic: Questions about using two u360 joysticks  (Read 797 times)
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« on: June 07, 2007, 03:03:50 pm »
I am wanting to do a bartop with 2 u360 joysticks and 6 player buttons + credit and coin.  If I understand correctly the u360 are seen as gamepads.  Since I can attach the buttons to one of the sticks I wont be using an encoder.  Will it be difficult to get mame or even windows to work with two of these.  Specificly for use in games like robotron etc.
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
Re: Questions about using two u360 joysticks
« Reply #1 on: June 07, 2007, 03:19:20 pm »
You should have absolutely no issues doing what you want to do.  I think you'll have to globally map each button in the MAME config, but other than that everything should be just fine!
Good luck!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
stephenp1983
« Reply #2 on: June 07, 2007, 03:35:16 pm »
I was just worried that windows might not handle to joysticks at the same time.  Thanks.
Chris G
  • Last login:April 16, 2023, 04:39:59 pm
« Reply #3 on: June 07, 2007, 03:40:35 pm »
Not a problem.
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #4 on: June 07, 2007, 10:43:41 pm »
Andy also released a version of the firmware that supports shift functionality, so you can have more than 8 buttons if you need...
If I do not respond to your post in a timely manner, feel free to PM me.
stephenp1983
« Reply #5 on: June 08, 2007, 08:17:08 am »
Yep thats great that was one of the main reason I went ahead and got one :)
Havok
  • Trade Count: (+17)
« Reply #6 on: June 08, 2007, 08:31:03 am »
The only issue you will run into is that Daphne will most likely not work properly with them, unless you use Joy2Key...
