Main > Main Forum
motherboard grounding?
OSCAR:
--- Quote from: shmokes on April 20, 2003, 10:36:51 pm ---Oscar, the inside of that cab looks strangely sinister. I don't trust it.
Nor should you.... ;)
HeadRusch:
OK What I want to know is where you got the HD and CDROM Mounting L Brackets...or are they just standard home depot L-Brackets with smaller screws used?
I was going to use plumbers tape to secure my HD and CD-Rom....
But l-brackets..whoda thunkit! :)
OSCAR:
--- Quote from: HeadRusch on April 21, 2003, 07:30:04 pm ---OK What I want to know is where you got the HD and CDROM Mounting L Brackets...or are they just standard home depot L-Brackets with smaller screws used?
If you are referring to mine.. the black brackets I used were left over from a radio installation kit, or perhaps a car amp kit, I can't quite remember for sure but it was definitely from some kind of car audio equipment. I scrounged around in the garage until I found something, and those brackets fit the hard drive perfect. :)
